crank shaft bolt
Old Dec 9, 2007 | 10:50 AM
ziggy81401's Avatar
crank shaft bolt
I'm replacing my timing belt. Which way do you turn the crank shaft bolt to remove it on a 2002 v6 tacoma, to the passenger side of the truck or drivers side?
Thank you
Old Dec 9, 2007 | 11:14 AM
eric-the-red's Avatar
Same way as other normal thread bolts, anticlockwise when looking at the engine from the front.
Old Dec 9, 2007 | 11:34 AM
ziggy81401's Avatar
Thank you! That is what I thought, this thing is on tight!
Old Dec 9, 2007 | 12:49 PM
Yeah, they're very hard to loosen. If you have an impact wrench try that. If not you can try using the starter. Get a 24" breaker bar and a deep 6-point socket, put the socket on the bolt with the bar under the passenger side frame rail. Then hit the starter for a second, you don't need much. Make sure the ignition system is disconnected first. That usually gets even the stubborn ones loose.
Old Dec 10, 2007 | 04:10 AM
MTL_4runner's Avatar
Right to tight and left to loose just like standard bolts.
Yes, it's on there VERY tight so make sure you retorque it properly when you're done too.
Amer
3.4 Swaps
19
Jun 5, 2017 10:43 AM
TJWilly
Jul 31, 2015 02:05 PM
yoterr
Jul 24, 2015 04:29 AM
v_man
Jul 23, 2015 04:01 PM
Iceman4193
Jul 15, 2015 04:48 PM
