Couple of Questions!?!?
Hi all.
Ok first off I want you all to check my math on somehting I have a 1990 runner with a man tany.
1. Math part of the text!
4" sup lift + 2" body lift+5.29 gears=35" tires
2. tech part of the test.
My steering box is leaking and I have two choices replace the box (+/- $345) or get a seal kit (+/- $150) with cost aside which would be better. other then a bad seal there is nothing worng with my steering box. and eather way I have to remove the steering box. has anyone don't this before? This is the first time I have had the option to just rebiuld the seal.
Which one would you'all go for!
Thanks for the help guys!!!
Matthew :alien:
Matthew :alien:
Sorry to leave this unanswered so long. 35s will fit with the lift mentioned, you will need 5.29 gears to turn them.
I would deffinatly rebuild the steering box instead of buying one off the shelf. If you have the time and ability to keep that $345 in your pocket.
TJWilly
Jul 31, 2015 02:05 PM
DrZero
18
Jul 24, 2015 11:31 PM
icentropy
Jul 14, 2015 10:23 AM
