Could someone please explain what Toyota was thinking??? (Defrost)
Old Sep 29, 2005 | 10:03 PM
motoracer47's Avatar
Originally Posted by AKTaco
He said in addition to the drier air, the A/C used a "heavier duty" blower motor, so it cut down on wear and tear when on high...
theres only one blower motor, so he was blowing smoke.
Old Sep 29, 2005 | 10:13 PM
CoedNaked's Avatar
Originally Posted by bike4miles
Also, the AC system needs to be turned on every month for matainance. Without this feature you would never turn it on all winter.
And if you don't run your A/C somewhat regularly you can build up MILDEW in the A/C lines which will really suck when you need your first blast of cold air come Summer time. Plus it's kinda unhealthy. So it's good that your vehicle runs the A/C to defrost.
Old Oct 1, 2005 | 08:05 AM
CynicX's Avatar
Originally Posted by Beartracker
Whats the deal with circulating the inside air??? Does this allow any outside air in or are you just blowing around stale air? Anyone know when it should be used and what for? Mike
The air is colder while recirculating the inside air. Instead of the A/C trying to cool 100 degree outside air, its recirculating the 70 defree inside air.
Plus it will help keep bad smells outside, but for the best effiency using the recirculating feature is always best.
Old Oct 1, 2005 | 02:29 PM
Diesel_Freak's Avatar
yep... like everyone's saying, AC helps to defog by drying the air... my 92 Jetta turns on the AC when you go to defrost... adn there's no off switch, it just uses the AC for Defrost/fog permanently.
matrad
Aug 26, 2024 08:21 AM
bigblue82
10
Jul 6, 2015 08:27 AM
cchinny
Jun 25, 2015 08:11 PM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
Old Red 94
Jun 16, 2015 08:32 PM
