Coolant Leak Question 3.4L Engine
Old Jan 26, 2005 | 08:15 AM
TacomaTRD's Avatar
Pull off the timing belt cover and see if your water pump is leaking. I have a slight leak on my 98, have seen pics on Yotatech that look similar, where it leaks on the passengers side of the pump. I had about 70K when my fan pulley bracket went, that is why I was inspecting... I plan on doing the TB and pump this spring after it warms up, actually have the parts waiting to install...
Old Jan 26, 2005 | 08:25 AM
Jared Ajlouny's Avatar
do you have the idiler and (some other one) pullies? you should buy them and if they are bad replace them...if not return them...they cost me around 160 AFTER employee discount!
Old Jan 26, 2005 | 02:39 PM
Ducseven's Avatar
No water in the oil, or vice versa. I have the V6. It was pressure tested and not a drop in pressure in 30 minutes......?
Oh well...
bigjstang
Jun 2, 2025 03:56 PM
Avenged
Jul 9, 2015 07:55 AM
Cplmike
Jul 8, 2015 08:47 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
HRDC0R19
Jul 5, 2015 06:43 PM
