Confused on radiator/tranmission cooler fixes
Old Nov 29, 2009 | 04:19 PM
GhostriderTx's Avatar
My 2001 SR5 is doing fine but I was planning to do a preventative fix for the strawberry milkshake. I am not trying to complicate everything but if i just replace the radiator with a new OEM one does that set my clock back to 2001? I got nine years with the factory original and would accept nine more with a new radiator. I have not looked under mine in a while so should I replace the hoses to the cooler also? I know that a separate cooler is an option but for some reason iwould like to keep it stock.
Old Nov 30, 2009 | 09:29 AM
SkidPalace's Avatar
Yes it will. Just use common sense when inspecting the hoses. Any sign of cracking or degradation and you'd be nuts not to replace. Scratch that. You'd be nuts not to replace regardless.
Old Nov 30, 2009 | 03:46 PM
Thank - I may do the cooler anyhow. I found the TRD cooler for under 200 bucks on line. That keeps it all Toyota and has a warranty.
Old Dec 1, 2009 | 10:42 AM
mt_goat's Avatar
$200!!! Are you kidding me, that's outragious.
Old Dec 1, 2009 | 11:06 AM
ESQ's Avatar
ESQ
I'm doing the switch to a 4454 right now with the remote bypass. Which is the pressure line from the tranny and which is the return to the tranny?
Old Dec 1, 2009 | 12:19 PM
mt_goat's Avatar
If you follow the lines all the way to the tranny the return line is the most rearward. The pressure line is the closest to the front of the tranny where the torque converter is.
Old Dec 1, 2009 | 12:35 PM
logsurfer's Avatar
For $200 you can get (4) 4454 tranny coolers!
Old Dec 1, 2009 | 01:16 PM
cosmophonic12's Avatar
I purchased the TRD/Hayden cooler at Checkers for 60.00 last spring. purchased the hardware separately and did a custom install .
jetpilot
Aug 15, 2015 06:48 AM
this_guy
Jul 31, 2015 01:27 PM
britishdudes2dr
Jul 25, 2015 06:47 AM
1996Taco
Jul 20, 2015 12:02 AM
Snort
Jul 9, 2015 03:58 PM
