coilover adjustment
Old Jul 4, 2003 | 07:54 AM
rjm's Avatar
rjm
coilover adjustment
am assuming it isn't very hard-but i have never done it before. i have the fabtech set up and would like to increase the driver side height alittle bit to even out the front end- can anybody walk me throught it/ thanks. rob
Old Jul 4, 2003 | 08:27 AM
Jboy's Avatar
I don`t have the Fabtech setup but you would need to remove the wheel, loosen the adjusting collar bolt, and use a spanner wrench and tighten the collar. I would use half turn increments and check ride height. Adjusting is the toughest part because you have to remove/replace wheel then measure until you get it where you want. Also, I suggest driving it to allow it to settle before finalizing the height you want. Hope this helps.
Old Jul 4, 2003 | 09:25 AM
rjm's Avatar
rjm
coilovers
thanks!
Old Jul 5, 2003 | 04:05 PM
User81720's Avatar
i have the fabtech setup. email me if you need help.
benjaminh
Jun 15, 2020 10:23 PM
mrcocoa
May 12, 2014 04:10 AM
Mr. iNCREDIBLE
Feb 20, 2013 04:24 PM
McQuaid
Jan 14, 2011 10:55 AM
4Runner202020
Oct 25, 2007 02:03 PM
