Coil Over Question
Old Apr 8, 2004 | 06:16 AM
NVRSASTK's Avatar
Coil Over Question
Does anyone know if a Tundra (fab tech) coil over will work on a 99 limited 4Runner. I guess the real question is: Is the 3 bolt location Pattern on the upper A arm the same? If the bolt pattern are the same, I believe the valving would be just right with a TJM and warn stuck on the front.. A little help would be appreciated
Old Apr 8, 2004 | 07:05 AM
superjoe83's Avatar
i think that the tundra bolts are spaced slightly farther apart than the taco/4runners
Old Apr 8, 2004 | 12:03 PM
loosehead's Avatar
Which Fabtech coilover, the Basic or the Performance? If its the Basic, it shouldn't matter because I believe it comes un-assembled and you would use your stock top plate to put the coilover together. I am not sure on the Performance Coilover. I would try to contact a retailer and ask, maybe you could get the Tundra valving with the Tacoma/4Runner topplate (isn't this what they do with the SAW's? Or is the top plate drilled for both app's?).
Old Apr 8, 2004 | 01:08 PM
Dr. Zhivago's Avatar
Away
On the SAW's the top plate is drilled for both applications. I'm not sure about the Fabtech pieces.
G
Old Apr 8, 2004 | 01:17 PM
loosehead's Avatar
G
I thought so...I would suspect that the Fabtech Performance coilovers are the same. I would also suspect that there is no difference in valving b/w there products, but that is just speculation on my part.
sandyota
Feb 4, 2021 11:16 AM
Sleaker
Aug 26, 2020 06:03 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Numberonedad6
Jul 30, 2015 07:10 PM
konah
Jul 30, 2015 02:08 PM
