Coil install
Old Mar 31, 2003 | 11:13 AM
TDiddy's Avatar
Coil install
Ok, I've been going around and around with this so I thought I'd just ask for your opinions.
How smart is it to attempt the install of my OME's (the fronts in particular) when I've never used a spring compressor?
I could spend $6 and rent a spring compressor, and do the whole job (with a friend).
For somewhere around $100, I could pull the fronts off myself, take them to Wheel Works or Firestone, have them compress and dis-assemble the fronts, remove the original parts I need, and then assemble the OME's. I'd then take them back home and swap them in myself.
Having someone do the whole install is just gonna cost too much.
I have all the threads and write-ups I can find on this install. Does anyone have any tips for using a spring compressor if I go that route? Has anyone ever had a compressor break on them?
Thanks in advance -
sandyota
Feb 4, 2021 11:16 AM
Sleaker
Aug 26, 2020 06:03 AM
Numberonedad6
Jul 30, 2015 07:10 PM
konah
Jul 30, 2015 02:08 PM
Massmayhem247
Jul 24, 2015 12:07 PM
