Code 420 Help!
Old Mar 20, 2009 | 12:54 PM
charitydillon's Avatar
Code 420 Help!
I have 1997 Tacoma Base Cab 4x4 (4 cyl.). I keep having a code 420. I have replaced all four fuel injectors the o2 sensor and the cataletic converter 3 times. When I start my truck, it shakes for about a min. or two. It feels like it is lacking something, no one seems to know. Any suggestions on the issue?
Old Mar 21, 2009 | 06:17 AM
97ltd4x4's Avatar
Need to scope and compare the sub1 and sub2 on a split screen meter for the code...
the drivability problem is probably what's killing your cats...so you need to get that taken care of and then either replace cats again or get one of these:
http://www.urdusa.com/index.php?cPat...tq8s885feh1eu7
and not wory about the code/cats anymore...unless at some point they clog...will happen if the drivability issue does not get resolved...
Old Mar 21, 2009 | 06:03 PM
RobD's Avatar
420 is the "Bob Marley" engine code.
It means your engine is stoned.
Old Mar 21, 2009 | 06:35 PM
bigt's Avatar
im about to check my 420 codes right now........ yup alllll goood..
Old Mar 21, 2009 | 06:48 PM
BigBallsMcFalls's Avatar
you did NOT replace the 02 sensors and cat 3 times. if you had that kind of loot,
you'd have gone to the dealer and got the job done first time.
anyhow if you did all this then it might be the ecu
Old Mar 22, 2009 | 10:43 AM
warriors_03's Avatar
You might check your MAF sensor.
I had that code, but after I replaced my o2 and A/F sensor, it cleared that code and popped a fuel system lean code and my MAF had bit the dust.
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
Draven023
Sep 26, 2015 12:41 PM
