Clutch sticking to the floor but not engaged
Old Mar 4, 2015 | 08:00 AM
luke0927's Avatar
98 4x4 3.4 5speed
I've seen the threads about the return springs, but I think this is the master cylinder wanted to see what you think before I swap it.
Some times with the clutch fully engaged more often if you have to hold for 30 plus seconds or so, it will just just stay stuck to the floor but it is not engaged and will drive with the pedal stuck to the floor.
Fluid is good but I'm guessing its not regulating the pressure and allowing it to drive with the clutch pedal in once it "sticks".
Thanks
Old Mar 5, 2015 | 02:23 PM
DOT3's Avatar
Seems like the master or slave cylinder.
If you've never replaced them then it's time to replace both. I have not had luck with the rebuild kits.
Your clutch also has issues with the clutch bushing. You should inspect and replace it also.
There are threads on this site.
Old Mar 7, 2015 | 02:52 PM
ThorInc's Avatar
Could be the pressure plate....it was on mine.
dumpster84
Apr 30, 2016 06:03 AM
shisha1999
Aug 14, 2015 01:33 AM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
