Chevy rear swap question
Old Feb 23, 2004 | 10:17 AM
I know a lot of you people out there are running the 88-98 Chevy rears. And a lot of you use a dual shackle setup. My questoins are:
1: is the dual shackle setup unpredictable in an off camber situation?
2: is there anybody out there running a Buggy spring setup instead?
3: How do the Chevies flex without the dual shackle setup?
4: How would I get around a 5 inch lift using the chevies without running blocks?
Any feedback on this would be appreciated
Old Feb 23, 2004 | 10:26 AM
sschaefer3's Avatar
1. I don't think so if done correctly
2. I don't know
3. I don't know we run a dual setup
4. Keep deaming, your looking at 4" of lift in a pickup and 3" in a 4Runner. The entire point of useing the springs is that they are soft, if you add leafs or make them stiffer you have defeated the purpose.
The other thing that I think very few realize is that the Chevy bushings are just like the Toyota bushings in the 3rd Gen lower control arms. The rubber is meant to flex and the inner sleeve has grip spikes, you following this? The rubber moves not the bolt pivot. If you use the Chevy shakle, which has the same grip spikes on the rear of the springs and you make a custom shakle for the Toyota frame to Chevy spring that is your best bet. The spiked bushings act as springs to pull the dual shakle back in the correct direction and it will never invert. You'll also need to shim the springs becase the front mount will then be on the flat part of the frame and the front of the diff will then in turn point downward. You'll also need to lower the bump stop points because if you push the Chevys beyond perfectly flat you'll sag em.
It works really well if you do it right, from what I have seen on Pirate, most miss the boat.
Here is ours:
http://fastq.com/~sschaefer/store.html#63Chevy
Old Feb 23, 2004 | 10:36 AM
I understand bout the shackles. as for the pinion pointing downwards, how many degrees is the shim you're using.
Old Feb 23, 2004 | 10:37 AM
sschaefer3's Avatar
Ours worked out to 6 degrees.
Old Feb 23, 2004 | 02:57 PM
alabamatoy's Avatar
Uh, no. I am running 5" All Pro fronts, and the chevys in the rear with a rancho add-a-leaf. This results in a spring that flexes almost exactly the same as the AP fronts, and gives about same lift as the AP fronts (which I admit sag like hell). Flexes very well.
Old Feb 23, 2004 | 03:27 PM
lunatic14r's Avatar
why do you want chevy rears??? is there a advantage??? are the to wide???
Old Feb 23, 2004 | 03:30 PM
Cebby's Avatar
You do know they are talking about springs, right?
coryc85
Sep 9, 2015 06:24 AM
icentropy
Jul 11, 2015 07:21 AM
Cplmike
Jul 8, 2015 08:47 PM
toyoda8488
Jul 5, 2015 10:18 PM
