checking for exhaust leaks
Old Sep 30, 2004 | 08:22 AM
evilcow's Avatar
Whats the best way to check for exhaust leaks? I'm pretty sure I have a exhaust leak. just dont know where,
Old Sep 30, 2004 | 08:30 AM
SloPoke's Avatar
Visually.
Get under there and check for the leak. It should have a small amount of soot/carbon showing through the leak. At least, when mine springs a leak, that's how I track it. Either that or do it with the engine running and feel around (careful to not burn or affixiate yourself) for hot exhaust coming from anywhere but the end terminataion opening in your exhaust. If you got a buddy to help, he can put his hand over the exhaust pipe to limit the amount coming out and try to force it through the leak maybe making it easier to track if there isn't any soot/carbon showing yet.
Good luck!
Old Oct 1, 2004 | 06:43 PM
nunsa's Avatar
Slopoke got it right, but you can also get yourself a bottle of soapy water and start spraying, you'll find it!
Old Oct 3, 2004 | 05:24 PM
evilcow's Avatar
Found it. It was the exhaust manifold. Looks like the gasket is blown by the #4 cylinder. Is changing the gasket a easy fix. Any tips?
Thanks
jasonty
41
Dec 23, 2018 01:00 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
the1998sr5
Jul 16, 2015 06:20 AM
nick b
Jul 11, 2015 04:38 AM
Coreyr384
Jul 10, 2015 11:13 AM
