Check engine light is on. What to do now?
Old Mar 29, 2005 | 09:59 AM
ikoror's Avatar
Lightbulb check engine light
Hi,
two months ago I got same problem-at high rpm(120 km/h on 2wd or 80-90km/h on 4wd) check engine light came up and I slow down about 20 km/h. I changed air filter, valves, cables, oils-nothing worked.
Then I made
1. http://www.4x4wire.com/toyota/mainte...a_4runner_30k/
Cleaning the Throttle Body……
2. http://www.4x4wire.com/toyota/minutemod/afm/
Adjusting the Air Flow Meter
problem gone!
Old Mar 29, 2005 | 11:25 AM
DonH's Avatar
They were able to clear the code for me,and its been ok after driving about 100 miles since. So far I checked the airfilter which was fine. Thanks again for the great info and fast response.
Don
Old Mar 30, 2005 | 04:50 PM
midiwall's Avatar
A quick side note...
That link's a little off, the document is actually at:
http://www.4x4wire.com/toyota/minutemods/afm/
(note the "S" in "minutemods")
Old Dec 21, 2009 | 11:53 AM
alil2cul4u's Avatar
Hey, guys. I was on my way home from Denver today which is about a 45 mile drive and about 15 miles out my check engine light came on. Now that I got home I checked the fault codes and I have a 21 and a 51. I had one before I believe it was the 51 because if I remember right that could be the Throttle Body Position Sensor?!
If anyone can tell me what the codes mean and how to fix? I did look up the codes one says signal switch the other says O2 sensor.
And if those are correct. can someone tell me how to check the O2 sensors to know which one I have to replace as they are very pricey
TIA
alil2cul4u
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Jdgarrison
Oct 1, 2015 05:22 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
94hiluxZE
Jun 22, 2015 10:42 AM
