check engine light, how to make it go away?
Old May 2, 2008 | 10:47 PM
Hasbeen's Avatar
You never did tell us the year/model/specs. Also, did you have any trouble symptoms before or since the CEL came on? They should have given her the codes, you want and need to verify their findings before replacing an expensive part such as an alternator, if that is the problem.
Old May 3, 2008 | 04:52 AM
mt_goat's Avatar
Originally Posted by mt_goat
Make sure you get the actual number of the code, like P0420 and not just a decription or guess as to what it is. Some codes can be multible possiblites.
Go back and get the code. If it is the alt it may just need new brushes.
Old May 3, 2008 | 06:58 AM
yongxing's Avatar
Year is 2001, SR5 model w/ the V6 engine.
The only modifications I have done are stereo and amplifier/sub install.
I will be back with the code.
Thanks
rbravo1
Jun 29, 2015 01:34 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
94hiluxZE
Jun 22, 2015 10:42 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
Dr. Evil
Jun 7, 2002 09:19 AM
