Check Engine Light
Old May 1, 2006 | 08:00 AM
slemay6's Avatar
Check Engine Light
2001 4runner 86000 miles Codes PO 440,441,446.They said it is the fuel system any guesses
Old May 1, 2006 | 09:18 PM
humanoid's Avatar
Check the gas cap and see if it's on correctly.
Old May 1, 2006 | 11:03 PM
midiwall's Avatar
This can help...
https://www.yotatech.com/forums/f128/obdii-trouble-codes-76363/
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
And I agree with Humanoid.. check the gas cap. Past that, the evap canister could be plugged.
Old May 2, 2006 | 05:31 PM
slemay6's Avatar
Yeah I tried the gascap no workie
Old May 3, 2006 | 05:52 AM
GSGALLANT's Avatar
Did you reset the codes after tightening the gas cap? The codes won't go away by themselves, so if you didn't do it, disconnect your battery for 5 or 10 minutes (or pull the ECU fuse) to reset your computer, then reconnect the battery (or re-install the ECU fuse), start the truck, and see if the CEL comes back.
Old May 5, 2006 | 05:09 PM
slemay6's Avatar
Yeah it comes back after around 100 miles after reset
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
colinmil
Jul 6, 2015 04:03 PM
