check engine light
Old May 23, 2003 | 03:28 PM
slutbag's Avatar
check engine light
my check engine light went on the other day and they told me that i had to replace the EGR valve gasket and temperature sensor and tube how much do you guys think it cost to repair because dealer quoted me $667 or can i do it myself.
let me know what you guys think
thanks
jorge
Old May 23, 2003 | 07:47 PM
tomus1000's Avatar
It doens't sound that hard. The EGR is easily accessable.
Hey, I see you are from CT also...
Old May 23, 2003 | 11:32 PM
AgRunner06's Avatar
Post
Yeah, the EGR is easy. I was told by a mechanic at Toyota that the only time the temp sensor goes out (om a 6cyl) is when it starts leaking. Otherwise it is usually good for quite a while.
It seems odd that they quoted you to replace the EGR gasket and the temp sensor tube. Is this on a 4cyl or 6cyl? I pretty sure that the temp sensor screws into the back of the block on the 6cyl. I looked at having mine replaced because I got a lean code and one of the problems it mentioned was the temp sensor.
You need to find out what the code is. Something doesn't seem quite right.
Old May 25, 2003 | 07:20 AM
slutbag's Avatar
it is a 3.0 v6 and i will try to find out what the codes were
thanks
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
colinmil
Jul 6, 2015 04:03 PM
