Cheaper fix for down travel. MAYBE
I have a 4runner with the sway away 2.0 standard travel coilovers. I have ot at about 3 inches of lift. I have ran this setup for almost two years, but the small amount of Down travel, about 2 inches, is getting old.
I searched around, and I put together that uniball uca's can give you about 3/4 inches of additional down travel when used with extended coil overs. Well that would be great except that I am in college and I cannot afford new coil overs.
So my question is.... And someone please tell me if I'm way of in my thoughts.
Could I use a top out spacer ( 1/4") on top of my coil overs, to technically lower where the travel stops. At the same time install uca's to keep the stock bj from binding up. I would keep my ride height at the exact same height. So I would crank my coil overs down the same amount as the spacer I add.
I do not think that I would create a problem with up travel if I do this, because there are stock bumpstops that hit long before the polyurethane bumps in the shaft would hit.
What do you all think. I know I'm being cheap, but I could save my self a grand and it may work fine. And no.... sas is not in the question.
You are asking for more droop. You will overextend the CVs and either pop them or they will pull apart. You can't go with extended CV axles because they still need to compress when the wheel travels up. Droop, especially excessive droop, causes CVs to pop because the flexible part of the CV is now working toward the edge of the CV bucket. The edge has less strength than deep in the bucket.
In short, Don't do it!
Well, I was just figuring it would be okay since companies make coilovers with extended travel to help with droop, or down travel. And that's why people buy aftermarket uca's. I was thinking a net of 1/2" or less of additional down travel
Peevedkitten
11
Aug 31, 2015 06:57 PM
yimbo
9
Aug 22, 2015 03:36 AM
FS[PacNorWest]: 1982 Toyota Long Bed Trailer
58rennur4
Aug 4, 2015 08:49 AM
FS[SouthCent]: TX Third Gen UCA and LCA low miles Taco
KyleT
Jul 21, 2015 07:54 PM
