Changing the oil myself for the first time
Old Mar 12, 2007 | 10:29 AM
Phat Ham's Avatar
Originally Posted by rocktown
Instead of taking the skid plate off, i just slip a plastic bag over the filter when i'm unscrewing it, the plastic bag will catch all the spilled oil.
I wish I had read this post before I changed the oil in my 4Runner for the first time last week. I didn't want to take the skidplate off so I reached through the wheelwell to unscrew the filter. I got the filter off without spilling much oil, but I couldn't get the filter back out through the wheel well. Slipped out of my hand onto the skidplate, upside down.
I ended up reaching in from the top, which I think is the way I'll do it from now on. You can't see what you're doing when you go from the top but it's actually not that hard to reach the filter.
Old Mar 12, 2007 | 10:36 AM
mkgarrison5's Avatar
i dont take the pan off to change the oil.. once in a while i will and spray it off and clean the under body with brake cleaner and all is well
Old Mar 12, 2007 | 11:27 AM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
Originally Posted by Phat Ham
Make sure you get the right grade bolt though. For something like the bolts holding on the skid plate it probably doesn't matter, but if you're dealing with suspension pieces or other highly stressed parts you'll want to make sure the bolt you get is strong enough. Not all bolts are created equal.
i forgot to mention that, always get grade 8 bolts for anything supporting loads. or even higher than grade 8 if you can fid it, but Home Depot/Lowes usually has grade 8 and thats fie.
Old Mar 12, 2007 | 12:05 PM
Tanto's Avatar
Toyota recommends 5w30 (it's on the oil cap).
Old Mar 12, 2007 | 12:22 PM
  #25
wa4x4's Avatar
Originally Posted by Elton
have fun you need to take the skid plate off turn the wheel all the way to the left then snake your arm up to the filter ive been useing mobil 1 clean 5,000 in 10w30 and useing a napa gold 1516 filter its for a ford but its bigger
You don't need to get at it from under...
I did it that way at school and some kid from Jiffy Lube walked by and laughed. I was like "What's so funny" and he points to the rubber fender liner and goes, "You could have just reached through there and you could have drained oil without taking off the skid plate".
Soo....fender liner trick works.
Old Mar 12, 2007 | 03:23 PM
  #26
twitchee2's Avatar
Thanks guys. I did use the the fender thing worked great. I took the skid off just so i could figure out what i was doing. I should of gone to home depot but it was $2/bolt not bad not great. as for grade 8 thats what i was thinking i would need.
Yont283
Sep 23, 2022 08:06 PM
Alaskan91
Sep 21, 2015 04:39 AM
serenity03k64
Jun 27, 2015 07:59 AM
NerfHerder-97SR5-
Jun 22, 2002 10:38 AM
