Changed spark plugs, now i have a high idle
Old May 7, 2010 | 06:51 PM
hungryeddy's Avatar
so today i replaced the oil, spark plugs, air filter, and oil filter... before my idle was at about 700 and now its at about 1500... any ideas?
i don't know if this matters, but i went from NGK plugs to bosch +4
HELP!
Old May 7, 2010 | 07:08 PM
kball's Avatar
You mean after it's warmed up it still idles that high?
Maybe you have a vacuum hose not attached..?
Old May 7, 2010 | 07:13 PM
GranVille-4crawler's Avatar
Turn your idle down lol. Could be that with your recent tune up your getting more spark =ing more rpms...?
Old May 7, 2010 | 07:19 PM
874runnersr5's Avatar
Yeah, could be that your engine is running correctly so now you gotta turn down your idle.
Old May 7, 2010 | 09:05 PM
hungryeddy's Avatar
can someone tell me how to do that? .......................... ROOKIE STATUS
pictures would be nice... if possible
Old May 7, 2010 | 09:36 PM
Kiroshu's Avatar
Ok Year/make/model? Make sure all vac lines if any where disconnected are re-connected. NGK is better anf recommended for toyotas... bosch was not the best way to go should have kept NGK.... But its your truck.
Old May 7, 2010 | 09:45 PM
hungryeddy's Avatar
I have a 97 4runner with the 6cyl engine
Old May 7, 2010 | 09:55 PM
Kiroshu's Avatar
Have you let it warm-up to see what its idle was then? Or is that what it is at operating temp? Theres a vac leak somwhere most likely. NOTE: "Never adjust the idle on a fuel injected engine." Or you will never get it back perfect. If its not idling properly then theres something wrong. Check vac leaks. Just back track and look around. Plug a vac ling into a wrong spot where another vac line is supose to go? Mixed up. Does it run rough upon this idle? Intake tube tight? Mass air flow plugged in?
Old May 7, 2010 | 10:17 PM
hungryeddy's Avatar
Its definately not a temp issue... I warmed it up for quite a bit and took about a 20 trip. I will check the lines but I highly doubt it since that was my first guess and I've checked them already...
Old Mar 2, 2012 | 08:07 AM
Gavin S.'s Avatar
Sorry to all for bumping a necro-thread, but I am having this exact same issue after a plug change on my 96 V6 4Runner. I've checked my hoses so I'm stumped. Thanks.
bryan34w
Jul 6, 2015 05:53 PM
Jnkml
Jul 6, 2015 01:20 PM
karbin
Jul 5, 2015 11:37 PM
elwood73
Jul 5, 2015 07:07 AM
