Changed my own oil for the first time..
Old Apr 5, 2003 | 08:22 PM
jx94148's Avatar
Originally posted by 98Tacoma
Ok a few questions on Synthetic or Regular:
1. Which is the perfered lube?
2. What happens if you switch back from synthetic, I heard it can blow seals??????
3. I installed a oil filter relocatioin kit, was there any benifit to that besides an extra qt. of oil???
1. I use Costal full synthetic because its cheapest.
2. In my oppinion that's a myth. If you swithch back you just have to change it more often.
3. Typically it makes it easier to reach the filter and makes it less messy to change because you don't spill as much.
Old Apr 5, 2003 | 08:25 PM
jx94148's Avatar
Originally posted by growinseed
If your looking for the 'grip' find some grip tape at a hardware store. The stock it to make steps less slippery. Before you install the next filter, wrap a piece around the filter, it has an adhesive back. Now you have an oem filter with the grip of fram, IMO the only valuble part from this brand.
Nathan
I started doing this a while ago after I learned about the lower quality design and construction if the Fram Sure Grip end. I use Purolator filters and add grip tape to help get it off when its time.
Old Apr 6, 2003 | 07:58 AM
98Tacoma's Avatar
Thanks
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
HRDC0R19
Jul 5, 2015 06:43 PM
