center console cup mod installation problem
Old Oct 13, 2004 | 10:07 AM
ranma21's Avatar
Hey guys, I am trying to do the cup holder mod. I got a 99 console, the e-brake handle, the mounting plate for both the e-brake and console. From what I read on yotatech, it should be a direct swap. But for some reason the new e-brake mounting plate would not align to the mounting hole, is like half a cm away. It looks like the square opening for the e-brake mounting plate on my 96 is not as big as the 99 and up model. It is so weird, I wonder if 99 and 00 or 02 has a different mounting plate since I am not sure which model I got. I was all excited to install them just now and I am like now. Please help please help!!! Thanks in advance!!
Old Oct 13, 2004 | 11:25 AM
User 051420's Avatar
My best suggestion is to use your 96 ebrake. I used my 97, unbolt, twist, dril and rebolt. It really wasn't that difficult. The only trouble I had was lining up the silver bracket.
Old Oct 13, 2004 | 11:33 AM
waskillywabbit's Avatar
Talking Bob's mods
Doesn't our resident YT guru Bob have a write-up on this? All he wants is for you to pull his finger now that he euthanized the squirrel, or fried him up for supper!
Old Oct 13, 2004 | 12:55 PM
SLC Punk's Avatar
I used my 97 bracket, drilled a new hole. Plugged the old hole with another bolt and silicone.
Old Oct 13, 2004 | 04:20 PM
ranma21's Avatar
Thanks guys!! I thought it would be a direct bolt on thing since I got everything form the yard. I might just use the original e-brake plate or grind some part of the hole to make the new e-brake mounting plate fit.
Old Oct 13, 2004 | 04:26 PM
NorCalVP's Avatar
Edited, because i'm a moron...
The two mounting brackets should be the same, i put a 99 console in my 96, and WT put an 01 console into his 98 (ithink) Got pics?
Steve
Old Oct 13, 2004 | 05:12 PM
Bob_98SR5's Avatar
what they all said
bob
Old Oct 13, 2004 | 05:20 PM
ranma21's Avatar
Originally Posted by NorCalVP
Are you talking about the metal bracket that the rear of the console bolts to? if so they yes they are different, but the 99-00 (looks similar to the 96 bracket but is a little shorter) will bolt up, and the 01-02 bracket (it's gold and has a bunch of other stuff on it) will bolt up too. Compare it to your 96 bracket, maybe the yard sent you the wrong bracket.....
Steve
I am not talking about the the metal bracket that the rear of the console bolts to. But the e-brake mounting plate. I have both of the 99-00 and 01-02 bracket, I did realize they are different compare to my 96 and they are perfectly fine. Thanks for your info Steve!!!
Old Oct 13, 2004 | 05:25 PM
ranma21's Avatar
Hey guys, know what!! I found the solution!!! I just reuse my 96 e-brake mounting plate and the 99 e-brake and it bolt right on. I just need to remove the small metal holder for the e-brake cable and it works flawlessly!!! So actually we can reuse the old e-brake mounting plate, a 99 console and its mounting bracket, and a 99 e-brake handle and we are set!!!! I am happy now!!
Old Oct 13, 2004 | 05:26 PM
ranma21's Avatar
Thanks for the advise guys!!!
Old Oct 13, 2004 | 05:50 PM
7inl35swinchtacoma99's Avatar
Guest
aaaaa what are you talking about
Old Oct 13, 2004 | 06:51 PM
ranma21's Avatar
Original 96 e-brake mounting plate and 99 e-brake handle
http://photobucket.com/albums/v497/h...t=IMGP0514.jpg
Finished product!!!
http://photobucket.com/albums/v497/h...t=IMGP0515.jpg
Old Oct 13, 2004 | 06:56 PM
Nice 399 Pice Automotive Electrical Repair Kit!!! I've got one of those..
Old Oct 13, 2004 | 06:59 PM
ranma21's Avatar
They are cheap and handy!!!
Old Oct 14, 2004 | 03:48 AM
WT's Avatar
WT
Ahh yes I have a 96' not a 98'
and sorry for being late seeeing this I did re-use my old bracket you are refering to since the newer one was off a little I looked through some older pics and it jogged my memmory since its been well over a year ago.
here a pic.... Left is the newer and the right is the 96'
Attached Thumbnails center console cup mod installation problem-center-console-027-wince-.jpg
Old Oct 14, 2004 | 05:06 AM
SLC Punk's Avatar
Finished product!!!
Glad it worked out for you.
Now you are a member in the elite 99+ console mod club!
Old Oct 14, 2004 | 07:56 AM
ranma21's Avatar
Thanks for the info I kept looking at your web site last evening wondering how can you fit the new bracket in there cuz mine is off by half an inches. I am glad mine finally work
icentropy
Jul 11, 2015 07:21 AM
tpd143
Jul 7, 2015 09:06 AM
Nickdigg
Jul 7, 2015 06:04 AM
ptb12
Jul 5, 2015 01:49 PM
