CEL Codes Pulled - Any thoughts?
Old Aug 10, 2005 | 04:19 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
Autozone pulled the following codes (excuse the description if it's incorrect... scribbling in the dark):
P0125 - Insufficient coolant temperature for closed loop fuel control
P1133 - manuf code, fuel/air metering (air/fuel sensor circute slow to respond, bank 1?)
P1135 - manuf code, fuel/air metering (Pedal position sensor A circuit intermittent?)
Is anyone familiar with these? I'm thinking emmisions related problems which SHOULD be covered under the emissions warranty. I have 91,400 miles. I'd prefer to have an idea what to expect before I let the stealership try to bulls--- me.
I reset the CEL twice and both times it came back after 4 miles of driving.
Old Aug 10, 2005 | 05:08 AM
rimpainter.com's Avatar
Any recent mods or changes (besides the CEL) Rick?
Old Aug 10, 2005 | 05:14 AM
lee's Avatar
lee
heres some google help:
"P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
My coolant temperature has been fine, and the level is fine. However, when I looked in a service manual (by “Haynes”), that same code is listed like this:
P0125 O2 Sensor heater circuit fault.
Wow – could this be my pre-catalytic converter Oxygen Sensor failing? What’s up with the strange description “Insufficient Coolant Temerature for Closed Loop Fuel Control”?
Anyway, if anyone has any experience with these error codes, I’d appreciate the help. Also, if it does turn out to be the O2 Sensor, what are the odds I’ve ruined my catalytic converters? I have two, since the vehicle is California Emissions. "
hope that helps?
Old Aug 10, 2005 | 08:28 AM
Rick F.'s Avatar
No mods or changes.
Old Aug 10, 2005 | 09:18 AM
MTL_4runner's Avatar
This page might help you get to the bottom of the issue:
http://www.4x4wire.com/toyota/4Runner/tech/O2_Sensor/
Sandman
Jul 14, 2015 12:36 PM
smiley52
Jul 11, 2015 05:16 AM
Roger Borba II
Jul 9, 2015 05:05 PM
Edionne13
Jul 9, 2015 01:59 PM
Jnkml
Jul 6, 2015 01:20 PM
