CEL Code: P0141
CEL Code: P0141
Hi-
CEL P0141-read Bank 1 Sensor 2 malfunctioning circuit heater...( or something close to that). Is this the rear 02 sensor and would my truck start/idle rough because of it? The 02 sensor before the Cat and the cat are new.
I have a 95 Tacoma 4x4 AT 130,000 mi.
Thanks!
Thanks!
unplug the sensors. if it's a 4 wire sensor, there are 2 wires the same color(white usually). that's the heater wires. with a DVOM on continuity check the 2 wires on the sensor harness. if continuity, sensor is good. if no continuity, it's bad. always better to double check and make sure it's the sensor and not the truck
Sam hain
19
Sep 30, 2015 08:25 AM
charlie_fong
Sep 27, 2015 10:06 PM
