can someone take a picture of the wiring behind the kick plate
Old Feb 28, 2009 | 03:38 PM
merace19's Avatar
I had a aftermarket alarm that I removed.
This pic I have one wire with connector and the other one was cut.
This shows all of it after the removal.
before removal
and what was removed. I am not sure I got it all or that I got too much.
Old Feb 28, 2009 | 03:50 PM
raydouble's Avatar
Does it start, run, drive?
Does everything work?
I'd take a pic but it's going to be a while before mine gets back with my wife.
Old Feb 28, 2009 | 03:52 PM
merace19's Avatar
Everything works Except the turn signals and hazard lights. I know all the bulbs are good. So I have a feeling i am missing a connection or missing a wire.
Old Feb 28, 2009 | 04:14 PM
raydouble's Avatar
Are all the fuses still intact?
Old Feb 28, 2009 | 04:16 PM
merace19's Avatar
checked all the fuses. I could not find one for the hazard lights.
Old Feb 28, 2009 | 04:21 PM
raydouble's Avatar
Taco or Runner?
3RZ or 5VZ?
Old Feb 28, 2009 | 04:23 PM
merace19's Avatar
Tacoma Prerunner 99 V6
Old Feb 28, 2009 | 04:32 PM
raydouble's Avatar
Does your horn work?
Mine is a 01 4Runner V6
I've got two possibilities
#24 Turn signals/Hazard flashers and #31 Horn/Hazard flashers
Pic from my owners manual.......
Attached Thumbnails can someone take a picture of the wiring behind the kick plate-untitled.jpg
Old Feb 28, 2009 | 04:37 PM
merace19's Avatar
4runner must be different. Mine does not have that.
Old Feb 28, 2009 | 04:44 PM
raydouble's Avatar
You've got no fuses at all in the cab? What about the pass side?
Old Feb 28, 2009 | 05:19 PM
merace19's Avatar
Yeah I got fuses.
Old Feb 28, 2009 | 05:54 PM
raydouble's Avatar
I'm going to guess the turn 10A covers the emergency flashers too.
So it was good?
You might want to double check against your owners manual, if you've got one.
Did your turn signals flash with the alarm turning off or on?
If the alarm controlled the lights at all, I would think you would need to hook some wires back up.
Old Feb 28, 2009 | 06:11 PM
merace19's Avatar
All fuses good. I know i am missing a wire or something somewhere. Both turn and hazards are out so that tells me its something I disconnected. But I am unsure if when prior owner installed the alarm that he removed one of the wires and replaced it with the alarm harness.
Old Feb 28, 2009 | 06:16 PM
Godzilla's Avatar
Turn 10A
Horn,Haz 15A
Are for the emerg. flashers
Old Feb 28, 2009 | 06:20 PM
merace19's Avatar
Where you getting the numbers?
Old Mar 1, 2009 | 10:46 AM
merace19's Avatar
Fixed it. Wnat to say Thanks to those that helped me........
Old Mar 1, 2009 | 11:13 AM
Godzilla's Avatar
What was the cause? Just in case anyone is ever in the same situation.
Old Mar 1, 2009 | 12:27 PM
merace19's Avatar
Head in ass situation. I did not check to see if I had pulled the wires off the hazard switch, I pulled it up and bam all was working fine. If I had been the one that installed this kit I would have had no problem taking it out. But the dealer lost the fob for it and just unplugged what they thought was right. So I got in the middle of this and had to work around and though it. But now I can tell you what every wire in the dash does and where it can be found.
jasonty
41
Dec 23, 2018 01:00 PM
BeMiceElf
Oct 10, 2015 09:40 PM
msane99
Jul 17, 2015 10:13 AM
88yodabasket
Jul 13, 2015 01:32 PM
Snort
Jul 9, 2015 03:58 PM
