Can someone help with body lift install?
Old Sep 22, 2010 | 01:04 PM
brian2sun's Avatar
Originally Posted by Murderedout99
iv thought about stacking washers under the airbox so it will line up right. and the kit comes with the radiator drop. does anyone know if thts a PITA?
ooh and what abou the shift lincage? mine an auto so... should i be good?
The airbox is bolted to the body so it would need to be lowered back down, not raised more (but you're probably not going to be able to do that very easily). I've seen 2 others' airboxes crack from BLs. One friend bought a cheap K&N wannabee air filter from Autozone for like $35 (IIRC) to replace his cracked airbox. I would just keep an eye on it, you may be ok. Mine is fine still.
I'm not sure about the linkage for a 2", I only have a 1" and I just loosened the one bolt on mine, lifted it and tightened it back down. The radiator drop doesn't look too bad. 4crawler's BL instructions should tell you what needs to be done to the linkage and anything else.
Old Sep 22, 2010 | 06:27 PM
Murderedout99's Avatar
iv looked it over like 45000000 times. lol but im puttin on dat. at my buddys shop. his dads done alot of bls so maby i can sleep easy tonight knowing that he may know a lil more than me about it. haha
Old Sep 22, 2010 | 08:08 PM
brian2sun's Avatar
Here's the BL instructions from 4crawler (which has all the necessary steps for 2"+ lifts toward the bottom):
http://www.4crawler.com/4x4/ForSale/...er/index.shtml
Old Sep 22, 2010 | 08:43 PM
Fink's Avatar
If you have a laptop and a camera I'd keep them handy - if you have problems just snap a pic of it and post it on here.
If you do it during a busy time on the forum I bet you'll get an answer pretty quick.
Fink
Old Sep 23, 2010 | 06:34 AM
  #25
Mauzer's Avatar
Yeah don't be worried, I was apprehensive as well but I was bored so I went out and started pulling trim pieces to see just how "hard" it would be, I loosened some of the body mount bolts and decided to just go for it. A couple hours later I was done and wondering what I thought was gonna be so hard.
Old Sep 24, 2010 | 08:02 AM
  #26
haha nice. i thought about doin that today but im prob. just gunna wait till 2moro. did your have the rad. drop kit?
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
Sep 4, 2015 09:27 AM
skoti89
Jul 6, 2015 07:45 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
