CA emissions vs. 49 state emissions 01-02 4Runner?
Old Mar 11, 2008 | 06:13 PM
element's Avatar
I’m curious about the difference between 49 state emissions and California emissions on the 01 and 02 4Runners.
The 01 and 02 4Runners only have one part number for the front catalytic converter and one for the back. This is different than other years that list different part numbers for "with" or "without" California emissions.
The catalyst sticker on my 02 says that it meets Federal AND CA emissions standard. The truck was originally purchased in Ohio.
I am beginning to believe there is not a difference between the two emissions standards for these years. Does anyone if there is a difference?
The computer maybe (is there more that one computer option for the 01-02 3.4L)?
Also, can you go to a muffler shop in CA and get these replaced or will they send you to the dealer?
Old Mar 11, 2008 | 06:43 PM
DeathCougar's Avatar
Does it say CA, or CAL?
Old Mar 11, 2008 | 07:07 PM
element's Avatar
Evenin' Mr. Cougar!
It actually spells out the word California.
This vehicle conforms to US EPA NLEV regulations applicable to gasoline fueled 2002 model year new LEV light duty trucks and to California regulations applicable to gasoline fueled 2002 model year new LEV light duty trucks
Whew, I thought I was bad for run on sentences!
The emissions system lists as: SFI A/F S, TWC(2), HO2S
Old Mar 11, 2008 | 07:17 PM
skjos's Avatar
Originally Posted by element
Evenin' Mr. Cougar!
That's exactly the same as my 2002 SR5, that was originally purchased in Nevada. I think all 2001 and 2002 were 50 state emissions and there is no difference between one sold in California and one sold in a different state. But I'm not positive about this.
Old Mar 11, 2008 | 07:28 PM
That must be an 01+ thing. I know many states are adopting the CA emissions regulations, so Toyota was just ahead of the game. If it says Fed and Cali, its legal in all 50 states.
Old Mar 11, 2008 | 07:46 PM
element's Avatar
Thanks for the input, guys. Anyone know if they’ll replace these at a muffler shop in California?
It seems fewer aftermarket options are available for the CA emissions cats.
Old Mar 11, 2008 | 08:00 PM
WCorbett's Avatar
california sux
Old Mar 12, 2008 | 10:23 AM
skjos's Avatar
I believe as long as your vehicle is not registered in CA that you can use a 49 state replacement cat. However, this may affect emission sensors... has anyone replaced a 01, 02 cat?
here are some cats I found:
http://www.autopartswarehouse.com/se...64+11779&Nty=1
Old Mar 12, 2008 | 10:42 AM
Stay away from aftermarket cats. There is a reason they are so cheap.
#1 The never fit right, and they look terrible.
#2 They are not made of the same materials, so they are much less effective. Many members on here that have installed them cannot pass smog tests, or throw codes becuase of this.
Besides that, all the cats say NOT FOR CA emissions. If your truck from the factory is 50 state legal, why are the aftermarket cats not 50 state legal?
Old Mar 12, 2008 | 11:27 AM
Man4God's Avatar
Originally Posted by WCorbett
california sux
+1
Old Mar 15, 2008 | 12:29 PM
element's Avatar
That’s really what got me wondering about California muffler shops and their ability to replace cats.
My assumptions:
- 01 and 02 have the same set of emissions standards for CA and 49 state
- The 49 state cats work with the 4runner computer to provide in spec emissions control (according to the Toyota computer)
Why aren’t the 49 state cats legal for use in California? Does this amount to cat companies not paying (or wanting to pay) for testing and certification by the CARB? I understand that their testing is very expensive.
Old Apr 17, 2008 | 04:17 PM
Steve J.'s Avatar
That's about it. CA cats have to be CARB approved. Shops can legally only install approved cats.
Good mailorder sources for CA cats-
Ecatalyticconverter.com
Convertergeek.com
"Direct fit" doesn't always mean it will just bolt on, I found out.
Old Apr 17, 2008 | 05:20 PM
toyota_mdt_tech's Avatar
Oxygen sensors vs air fuel ratio sensors.
Old Apr 23, 2008 | 07:33 PM
element's Avatar
Thanks for the additional information.
Steve, I quoted you here.
Old Apr 23, 2008 | 09:17 PM
Steveh29's Avatar
I'll have to argue that point. I've used aftermarket cats on several vehicles all in Los Angeles, CA. They all had no problem passing smog at any time. One truck went through a couple of cats all at my own doing - banged them up on rocks. However three other vehicles (Subaru, Honda and a Ford Mustang) went for years and years (8+) with never a problem with the aftermarket cat or smog testing.
I'd say it really depends on the aftermarket cat and the year model of the vehicle. For example an aftermarket cat for my 1995 4Runner was about $80 at King Muffler in Van Nuys, CA. However for the later model Mustang and Honda they were about $200.
As for the look and fit, that depends on the shop's skills and the vehicle in question. There are probably some vehicles where an aftermarket wouldnt' fit right - late model Camaros come to mind where they're tucked up on the passenger's side footwell. But for my truck and the other vehicles, they were very similar if not identical in appearance. The main difference was they were weld-in cats instead of flanged bolt in cats.
Steve
Old Sep 30, 2010 | 11:26 AM
spitfire4's Avatar
Ive got a 95 3.slow and wondering if I can change my CA ECU to the FED ECU. My eng light is on again and Im pretty sure its my cheap boach O2 sensors X2. so my next plan is to install a FED ECU and use only 1 O2.... thoughts??????
Old Sep 30, 2010 | 12:02 PM
Nelsonmd's Avatar
Mine is a 49 state 4runner, and I still have 2 O2 sensors. You still have have to have them both. Just get denso ones of amazon, it will be cheaper than getting a new ECU.
Old Sep 30, 2010 | 12:35 PM
myyota's Avatar
california sux
That is an absolute fact, i just moved out of the peoples republic of California three months ago. I now live in Idaho, there is no smog testing required on anything here, and you can do a lot of stuff here that is illegal in California.
Old Sep 30, 2010 | 01:32 PM
hross14's Avatar
i moved 6 years ago----sad that i was run out of my state.....but things were going too crazy!!!
Constitution seems like cliff-notes there--at least Texas has the rest of the state keeping Austin in Check.
Flying91
45
Apr 11, 2024 04:39 PM
BeMiceElf
Oct 10, 2015 09:40 PM
msane99
Jul 17, 2015 10:13 AM
msane99
Jul 11, 2015 08:08 PM
timmJ
Jul 7, 2015 02:01 PM
