A/C makes idle low
Old Sep 18, 2004 | 09:12 AM
sand_box81's Avatar
Post A/C makes idle low
any one know what that little thing is that kicks up the idle when you turn on the a/c,or where it sits in the 3.sloe engine bay. I couldnt find it in the haynes manual. Maybe about time to get a chiltions. I hope some one can help ,thanx
:rockband: :bounce2: :bounce2: :bounce2: :bounce2: :bounce2: :bounce2:
Old Sep 18, 2004 | 10:15 AM
nunsa's Avatar
It's on the passenger side right in the middle, there's a lot of vac. lines going to it, it's a big screw, with the ac on, turn your idle up, but before doing so make sure your curb idle is set correctly (850 rpm's), if it is set correctly then go ahead and turn your ac idle up!
Good Luck!
Old Sep 18, 2004 | 11:47 AM
sand_box81's Avatar
hey thanx I'll try it
Old Sep 18, 2004 | 12:07 PM
sand_box81's Avatar
if the idle changes whem I adjust the screw and the ac is off could that mean I have a vacume leak????
Old Sep 18, 2004 | 02:38 PM
sand_box81's Avatar
still no fix for the low Idle when the ac is on
Old Sep 18, 2004 | 06:23 PM
okidoc's Avatar
This is a minor prob w/mine too.
bump
Old Sep 18, 2004 | 08:43 PM
AF1's Avatar
AF1
I have asked this question a few times on the board with no fix....If you can find a fix please let me know.....sometimes mine gets so low it will not even kick the compressor on...no cool air in heavy traffic.....good luck
Charecter1
Nov 6, 2023 10:08 AM
MO transplant
Apr 23, 2023 11:58 AM
jbv808
Aug 6, 2021 04:47 PM
bryan34w
Jul 6, 2015 05:53 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
