A/C help?
Old Jun 11, 2005 | 08:47 AM
A/C help?
Has anyone here replaced just the A/C clutch on thier compressor? Mine locked up, but the compressor was working fine, and cold. I would rather just fix the clutch if I can, because then I dont have to pay the expensive R12 freon.
Thanks
Kent
Old Jun 16, 2005 | 12:24 PM
So... Noone has had A/C clutch problems?
Well, I guese I will take a gamble and try for just replacing the clutch.
Kent
Old Jun 16, 2005 | 12:46 PM
Flamedx4's Avatar
On most compressors it's pretty simple. The clutch comes right off the front.
Old Jun 16, 2005 | 12:48 PM
Steveh29's Avatar
It's a fairly easy repair. Hardest part for me was getting the nut out of the compressor shaft. You'll also probably need a puller to get the old clutch off. Some compressors require shims on the clutch to set distance between the pully and clutch face. It's not that hard to set up though.
Old Jun 16, 2005 | 01:01 PM
Flamedx4's Avatar
Take the nut off the front of the drive plate. Use a strap wrench (or big channel locks) to hold the drive plate from turning. Remove the drive plate. Watch for spacers and make sure you put them back correctly. Remove circlip and remove the pulley. Disconnect the clutch coil ground wire. Remove the circlip that holds the coil in place and pull the coil off. If it indexes with a pin, note how it lines up and reinstall it the same way.
There are variations of this, but they all work about the same way.
Attached Thumbnails A/C help?-ac-clutch.jpg
Old Jun 16, 2005 | 02:31 PM
Awesome, thanks for the pic too!
Badlander
Oct 10, 2015 08:05 PM
Ktm526
Oct 7, 2015 05:14 AM
bryan34w
12
Sep 30, 2015 02:50 PM
BimmerSage
Sep 17, 2015 11:48 PM
Tacoma1313
Sep 8, 2015 01:27 PM
