A/C blowing fuses? What could it be?
2000 Camry Blowing 10Amp fuses.
I had the same problem. Without the engine running the inside fan and A/C button worked fine. With the engine running, as soon as I pressed the A/C button, the 10amp fan motor blew. Turned out that the compressor clutch is frozen and has plastic looking epoxy coming out of it .With the compressor unplugged the fuse is good . So now I just need to replace the clutch!
Hey man. I really appreciate the thread you started. I know you may not be available here seeing as you wrote this 7 years ago and may not remember much about it but I'd like to ask anyway. I have 2 questions: 1. Do you remember where the plug for the a.c. compressor on this truck was and 2. Was the "gunk" you rendered to almost like a tar. Thanks man I appreciate it.
Tips for removing clutch
Hi all - reviving this old thread because I think I am having the same issue as the OP. I am deciding whether or not to tackle removing/replacing the a/c compressor clutch. How did you get the bolt off the pressure plate without the SST? Thanks for any advice on the job. Cheers.
RyanJ989
11
Apr 7, 2021 09:41 AM
Bourbonblues
Dec 15, 2017 05:43 PM
Gone Fission
Sep 4, 2015 12:18 PM
