Buying Used Rim's 3.75 BS or 4.25 ? QUICK HELP PLEASE
Old Jun 23, 2005 | 06:53 AM
4Hummer's Avatar
Ive been running my 33" x 12.5" x 15" Mickey Thompson tires for about a month now. they were mounted on the Stock 15"x7" Rims and are cupping due to the small rim and wide tire.
I have a buddy that will sell me some used rims 15"x8" for $20.00 the set. he has two set's One with 3.75" Backspacing and the other with 4.25" !
Which will fit better ? I've searched checked out Rogers Site and still cant decided. Stock backspacing it 4.75" I belive so should I grab the 4.25" Than ?
Old Jun 23, 2005 | 07:01 AM
Cebby's Avatar
Closer to stock the better. Less BS = larger scrub radius = more rubbing at firewall and valence.
Old Jun 23, 2005 | 07:10 AM
Fink's Avatar
I had 3.75" backspacing on my 2nd gen with 33x12.50R15 BFG Mudders and had little to no rub after trimming the valence and plasma cutting the pinch weld. If you have already trimmed everything then I would suggest the 3.75"...if hes a good buddy, get one set, try them and if they don't work go back and get the other set...you'll only be out the mounting cost.
Fink
EDIT: Just remembered that you had a 3" body lift, you should be fine without trimming. I would go 3.75, they will stick out more from the fender and give it a more aggressive look. All personal preference at this point I would assume.
chukarhunt
Dec 8, 2019 11:39 AM
jasonty
41
Dec 23, 2018 01:00 PM
Regency
Sep 4, 2015 01:32 PM
Nailit69
Diesel Swaps
Jul 21, 2015 05:28 PM
Yotoder865
Jul 9, 2015 07:51 PM
