Buy a 98 TRD for 11,500 or 99 non-TRD for 13,500?
Old Apr 22, 2004 | 10:37 AM
baileymoto's Avatar
both are identical- white, 5 speed, 2.7, 4x4, xtracab, about 55k miles. the 98 for 11,500 has the black fender flares, tachometer, and i believe the TRD options (ill verify). the 1999 is not a TRD, doesnt have a tach, but is toyota certified and has a warranty until 100k miles.
the 98 TRD seems to have a slight 'noise' coming from the exhaust that the 99 does not. its not a 'tick' but a very very slight 'sputter'. both trucks seem to run and ride excellent however.
what would YOU do? i think the certification (which is transferable) may be worth the extra 2k. however, i do really like having a tachometer, which i suppose i could just add to the 99 if i decide to get it, and im not sure what is all different having the TRD option. i do plan on lifting it a few inches right off the bat with a coil over system, king or fabtech, and plan on going with 33's. i will be doing some offroading; dunes, river bottom, some trails, etc.
i need to figure this out by tomorrow!
Old Apr 22, 2004 | 10:49 AM
Churnd's Avatar
Easy... get the TRD and fix the noise. Or see if the owner will knock something off the price to compensate for the cost of fixing it. But if at all possible, stick with the TRD. You won't regret it.
Old Apr 22, 2004 | 10:53 AM
baileymoto's Avatar
what is all different about the TRD? on a stock truck you get the bilstein shocks (which get replaced with the lift anyways), larger tires, and a locking rear. does the locking rear on the 4x4 make all that much of a difference?
Old Apr 22, 2004 | 10:54 AM
Good Times's Avatar
the 98 trd sounds like the ticket here. doesn't the trd's come w/ the locking rear diff? shoot i'm all for the rear locker btw
good luck!
Old Apr 22, 2004 | 11:51 AM
SLC Punk's Avatar
If the TRD has the rear locker and the non-trd does not (did they even offer the locker in a non-trd?) then go for the TRD. Get the one with the rear locker! I wish I had!!
Old Apr 22, 2004 | 12:10 PM
Churnd's Avatar
It makes all the difference in the world.
You'll be able to arguably go more places in a stock locked rig than a lifted open diff rig with bigger tires. Traction is everything, and you're only getting half of it with open diffs.
Old Apr 22, 2004 | 12:12 PM
rimpainter.com's Avatar
I agree, 98 TRD.
I cant believe I sold my 98 LTD TRD. What an idiot.
Old Apr 24, 2004 | 06:31 AM
X-AWDriver's Avatar
I personally look for a V6 instead of the 4 banger.
Old Apr 24, 2004 | 02:37 PM
kenandjenn's Avatar
The 4 cyl with the TRD package will NOT have a locking diff. My prerunner is a 4cyl TRD and the manual says the locker is just for the V-6. It will have the Bilstein shocks and larger tires.
Old Apr 24, 2004 | 02:40 PM
kenandjenn's Avatar
I say go for the 99. The TRD package isn't worth much in the 4cyl trucks. NO LOCKER! The locker only comes in the V-6 TRD trucks. Get the newer truck with the better warrenty and then do your mods to that.
Old Apr 24, 2004 | 06:07 PM
Sherpa's Avatar
I agree. Get the 1999 with the great warranty. You would likely upgrade much of the stuff offered by the TRD anyway. That warranty is really hard to beat!!!
-Sherpa
Old Apr 24, 2004 | 06:09 PM
Sherpa's Avatar
SLC Punk is correct. Get whichever one has the locker. If they both have a locker, then I'll stick with my original comment and suggest the 1999. I really like having a tachometer, so I'd just figure out a way to add one.
-S
Regency
Sep 4, 2015 01:32 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
Toyvana
Jul 29, 2015 10:47 PM
Cplmike
Jul 8, 2015 08:47 PM
