burning?
Old Nov 25, 2002 | 07:37 PM
Patrick D's Avatar
burning?
I have a 2000 3.4 SR5 4wd and I was heading out today and as I was merging onto the freeway I floored it and it smelled like something was burning in my engine. I've noticed this before but it seemed like the smell had gotten stronger. I had changed my oil 2,000 miles ago and it was Amsoil so I don't think its that. I checked all of my fluids and they seemed fine. If someone could give me an idea to what that smell is, I will appreciate it.
Oh by the way, I have 58,800 miles on the runner so maybe I am due for an ATF change?
Old Nov 25, 2002 | 07:45 PM
Robinhood150's Avatar
What did it smell like? Paper, wood, plastic, rubber, oil, etc...?
Smells that I can think of are oil, ATF, antifreeze, brakes, and tires.
Steve
Jay's Avatar
Jay
Any leaks?
Plastic bag on the exhaust?
Old Nov 25, 2002 | 07:47 PM
I've gotten the same thing in my '91 4Runner when I floor it. I haven't been able to track down what it is, but I'm positive that it's because of being floored, because I only get the smell after I've floored it, or even after going up a steep hill/grade. Usually after running at higher RPMs for an extended period of time, and flooring it are the only times that I get the smell. So your guess is as good as mine, I changed my ATF about 3 months ago (1500 miles or so) and didn't change anything (except it shifts a lot nicer now )
-Braden
Old Nov 25, 2002 | 08:35 PM
hmmm, is it possible that it is the Amsoil? , because like Patrick D, I just switched to Amsoil on my last oil change (which was 2 weeks ago) and I smell something burnt also when I floor it. I checked for leaksn and there were none. But here is the kicker, I just had a Transmission flush done 3 days ago and also converted to Amsoil Universal ATF, now the smell is no longer there when I floor it (or accelerating uphill)
Old Nov 25, 2002 | 08:39 PM
Patrick D's Avatar
There are no leaks on my runner and I can't quit place the source of the burning smell though I did recognize that it was a burning smell so maybe I just need to think on what it smelled like.
Also it is similiar to the problems that were discribed, it happens at high RPM's and when I am traveling up a hill. I will probably switch over to Amsoil ATF soon and hopefully that will fix it.
Any other opinions would be great.
Old Nov 26, 2002 | 03:36 PM
Patrick D's Avatar
Ok, it smells like burning electronics.
Old Nov 26, 2002 | 05:18 PM
Bentaxel 26's Avatar
The smell you guys are smelling is the smell of hot metal, i have the same problem on my 93 4Runner, execpt mine is a little more often because i have 35 inch tires and 4.88 gearing. it smells like burning electronics, but it is just your engine, no harm is done i have checked it out a million times, and torn my engine apart to look for wareing but ther is none. almost all 4Runners that i have been it have that same smell when engine is running at high temps.
puddlepirate
Jul 30, 2016 06:29 PM
shooter86314
Jan 7, 2016 07:05 AM
dzldust
7
Oct 6, 2015 05:39 AM
viesail
Sep 21, 2015 06:00 AM
sonorn67
Sep 19, 2015 05:39 PM
