A Bunch of Suspension questions
Old Jan 31, 2006 | 10:14 AM
Deathmage's Avatar
Ok, I just got my engine rebuilt. I have 162k and would like to have my car better than new.
- Which wear-and-tear parts should I replace/upgrade first? what brand names for strength and durability?
- I want to do some light/medium offroading.
- 4 inch lift a standard?
- 33 tires too much?
- any other suggestions?
Old Jan 31, 2006 | 10:16 AM
ebelen1's Avatar
Suspension should be first if you still have the original equipment. Many do a combo lift of suspension and body lift to get to 4". Read up on the Tundra lift for more info.
garrett1478's Avatar
i don't know if anyone has ever run 33's on a 3rd gen. you might want to search and find out.
Old Jan 31, 2006 | 10:19 AM
bamachem's Avatar
yeah... search for "Tundra TRD Lift" and you'll find tons of info.
to spell it out for ya, a 2.0" to 2.5" suspension lift for the front with a 2.5"-3.5" lift for the rear along with a 1" to 2" body lift is common to run either 285/75-16 or 305/70-16's (both are metric 33's that will fit your 16" wheels)
Old Jan 31, 2006 | 11:57 AM
Deathmage's Avatar
so the tundra's got the similar/same suspension as the runner? I'm also trying to avoid 'sagging' as much as possible. not sure if I want to go with a body lift.. pretty ugly, but 2" wouldn't be bad. 4" suspension lift sound about right, though.
Old Jan 31, 2006 | 12:24 PM
ebelen1's Avatar
4" is too much on the CV angles up front. You'll also have trouble matching the rear to get 4" of lift just from a suspension lift.
Old Jan 31, 2006 | 01:22 PM
MTL_4runner's Avatar
You'd do much better to do 2-3 inches with suspension and 1-2" on the body lift as a combo.
That way you won't have any CV issues like you would with 4" of pure suspension lift as Edwin mentioned.
Old Jan 31, 2006 | 03:22 PM
noahrexion's Avatar
why lift at all if you will be doing light-moderate offroading?
It seems many people just do it for the looks nowadays. My basically stock Runner does great for light-moderate offroading. But if you are going to lift then the Tundra/OME seems the way to go.
Old Jan 31, 2006 | 04:21 PM
bamachem's Avatar
dude, it's all be done, the problems have been worked out, and the "kit" has been put together.
https://www.yotatech.com/forums/f37/most-complete-3rd-gen-4runner-lift-kit-ever-offered-featuring-tundra-trd-coils-77540/
add a 1" 4crawler body lift to that and you're set.
montanatruck
Feb 26, 2017 07:07 AM
skoti89
Sep 11, 2015 07:46 AM
B1gR3d
Aug 1, 2015 10:10 PM
coffey50
Jul 28, 2015 10:55 AM
Vargntucson
Jul 4, 2015 12:15 PM
