Broken Rear lug nut stud. Difficult repair?
Old Mar 1, 2010 | 02:34 PM
mudinyeri's Avatar
Originally Posted by Elton
new lug nut and a stack of thick washers
You can get it to catch without any of the splines engaged? I've tried the stack of washers and just throwing an old wheel on there methods and the lug always spins on me.
Old Mar 1, 2010 | 02:37 PM
wyoming9's Avatar
Red face
In all the years I have never pressed a stud in the axle.
I have also changed quite a few studs broke by idiots .
I cut the stud flush off with a cut off wheel, center punch the stud I have a special made tool for the air hammer pops the broke stud out .
to install i use a lug nut of the correct thread pitch put on with the flat side toward the axle 1/2" impact draw it right in .
No drama no bearings no big $$$$$$ repair bills
Old Mar 1, 2010 | 06:14 PM
aowRS's Avatar
Originally Posted by Gerdo
Can't you... take off the wheel, take off the drum and pound out the broken stud. Then slide the stud in from behind and tighten a lug nut on and suck it back in ???
+1,000
Andreas
Old Mar 6, 2010 | 01:02 AM
wyoming9's Avatar
Red face
This is like changing front brake pads by removing the whole caliper taking it to a press to push the piston in and remove the pads .
i have seen this done just shake my head and walk away
Old Mar 6, 2010 | 04:36 AM
  #25
Gerdo's Avatar
We are off topic but you don't need to remove the caliper off and put it into a press to retract the piston. While on the vehicle use the old brake pad and a c clamp to push it back in. If you have both off then you may have to clamp the other side to keep it from pushing further out.
Old Mar 21, 2010 | 02:00 PM
  #26
bigtrucknwheels's Avatar
I take it you didn't read the part where he says he just shakes his head and walks away...
the1998sr5
15
Jul 14, 2020 08:35 PM
mdev126
Oct 4, 2015 04:48 AM
Whatever123
Sep 30, 2015 12:12 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
Cdn-wilderness
Jul 10, 2015 07:43 PM
