breathers
Old May 13, 2003 | 02:13 PM
MNBOY's Avatar
breathers
I need to replace the clutch in my truck, and thought I would extend the breathers on the tranny and transfer case while I had everything out. Anyone know what the thread size is on the breathers? I'd rather pick up plumbing fittings and do it myself than order the Toyota parts that are mentioned in the Tech section. Are they the same thread size as the axle breathers? Thanks in advance for saving me some searching.
Old May 13, 2003 | 02:49 PM
jroc's Avatar
Do you run your truck under water to the point that it comes in the cab about ankle deep? If not there is no reason to do this. The breathers are at the top of the tranny and the transfer, at least they are on my truck. What tranny do you have?
Old May 13, 2003 | 03:21 PM
MNBOY's Avatar
I have a 5 speed and yes, the water has been ankle deep in the cab. I guess it was stupid of me to open the door to check the depth.
Old May 14, 2003 | 07:40 AM
mtnfreak's Avatar
I haven't seen the tranny/xfer breathers except by looking at them under the truck with a mirror. They appear to be the same as the diff breathers. If so, the threads are metric. 1/8" fittings can be forced in, but you risk damaging the threads, especially if the tranny/xfer cases are aluminum. For the rear diiff, forcing brass into steel is no problem, but for something like a tranny I'd be worried about getting any shavings inside.
Old May 14, 2003 | 10:44 AM
rabidbeaverbaby's Avatar
check out this link
http://4crawler.cruiserpages.com/4x4...html#Breathers
Old May 14, 2003 | 01:47 PM
MNBOY's Avatar
Thanks. That's exactly the info I needed in the link.
jashoeuh
Nov 18, 2024 08:08 AM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
scottyg486
Jul 19, 2015 05:34 PM
smr4runner
31
Apr 29, 2005 09:37 AM
AgRunner06
Jun 4, 2004 07:35 AM
