Braking Question!
Old Apr 30, 2015 | 07:57 PM
funcrazy1's Avatar
Braking Question!
Hey guys here is my question on my 2000 4runner 4x4 3inch lift OME 1in body lift! When I'm pressing on the brakes little hard it will pull to the right but when I'm done pressing the brakes it will shoot to the left! What I've replaced both LBJ both calipers both brakes lines for the front. It still causing the issue. Now I wonder if my alignment is causing it here the alignment photos.
When I first got her aligned
about 8 months later for alignment
I've order some SPC adjustable UCA see if this helps.
Old Apr 30, 2015 | 08:31 PM
maachine's Avatar
sounds to me like the passenger side might be grabbing more, you correct for it, then when letting off the brake, your correction pulls you back to the left?
i'd also check for wheel bearing and tie rod play.
Old May 1, 2015 | 03:24 PM
fierohink's Avatar
Have you checked your steering rack? You could have play in the bushings allowing movement.
fountain
Dec 31, 2015 06:08 AM
CanRunner
Jul 20, 2015 01:29 PM
Johntom240
7
Jul 13, 2015 12:18 AM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
