Brake warping at 20000 miles! Is this normal?
Old Oct 21, 2004 | 11:12 AM
03TRDBlack's Avatar
My rotors are starting to grab weird when I brake which leads me to believe that they are becoming warped. The thing is that my truck only has 20000 miles exactly on it. Is this normal? Should I head to the dealer to see if this is a warranty item?
My truck is a 2003 Double Cab TRD.
Old Oct 21, 2004 | 11:13 AM
rimpainter.com's Avatar
No it isn't normal, but it does happen. I am not sure, but if you are still under warranty you might be covered. I would really push the issue with the service department. That is just lame. Pads I can understand, but rotors? No, they should take care of that for you.
Old Oct 21, 2004 | 11:19 AM
03TRDBlack's Avatar
Well, I hope so, but since I have bigger tires and different rims, they are going to try and say that is what caused the problem. I hate the dealer...arrrrgh.
Old Oct 21, 2004 | 11:20 AM
SLC Punk's Avatar
I doubt they will cover it. Most likely they will say that is a wear and tear part and won't fix it. The only time I heard of a dealer fixing rotors as a warrenty is with my mom's 2003 Lexus ES300, but she only had 5K miles on it.
Old Oct 21, 2004 | 12:16 PM
fiveofeen's Avatar
it can happen, worst case change your orignial wheels/tires back on before you go. are you hard on the brakes? a lot of freeway braking? those conditions are more likley to cause warping.
its a toss up, depends on what side of the bed the service manager woke up on. i'm sure they could if they wanted to.
Old Oct 21, 2004 | 12:56 PM
roger's Avatar
You should definitely push the issue...sure it's a wear item, but 20k? Come on. My Taco has 104k and the rotors aren't warped yet. If you still have the stock wheels/tires, you may want to put them back on before you take it in.
Old Oct 21, 2004 | 01:02 PM
Manioca35's Avatar
My rotors are warped - bought the truck at 37K, and they had already been turned once, so my guess is that you're not totally alone. Do much mountain driving?
Old Oct 21, 2004 | 03:50 PM
WT's Avatar
WT
Maybe I was lucky but I had mine replaced by my dealer right before it hit 40,000 but I did complain a few times prior and they said they didnt see any problems. They replaced the rotors less the cost of pads that I paid for so I think I paid under 20 bucks and got new rotors. I say worth a try...
Old Oct 22, 2004 | 07:22 AM
03TRDBlack's Avatar
The dealer is going to re-surface the rotors for me free and I'm going to replace the brake pads. Basically I'm just paying for the brake pads. That worked out well.
Old Oct 22, 2004 | 07:30 AM
Good to hear...but expect the problem to return. I am just warning you. Turning the rotors does not have a good track record on Toyota's with warpage.
Ask them what they will do if the shimee comes back and document it.
Eggslinger
Jun 8, 2019 03:32 PM
Johntom240
7
Jul 13, 2015 12:18 AM
smiley52
Jul 11, 2015 05:16 AM
87turboPA
Jul 9, 2015 05:58 AM
