Blew a spark plug. Need new cylinder head. Wow. Fail.
Old Jan 10, 2010 | 03:48 PM
1990yota-pickup's Avatar
check this out this may help you save alot of money.. and if you got half a idea on how to use a tool this will get the job done
http://www.timesert.com/html/sparkplug.html
Old Jan 10, 2010 | 04:25 PM
ESQ's Avatar
ESQ
That can be fixed by a competent machinist.
Old Jan 10, 2010 | 08:29 PM
stir_fry_boy's Avatar
If you are still looking for a head, go to car-part.com and look for one in your area. If you find one, you may not have to pay for shipping, but there probably will be a core. I was able to find a lot of stuff for my 02' on car-part.com even though every junk yard here in UT never sees that new of T4Rs. You may be able to find one cheaper than $235 or whatever you said it was.
Old Jan 11, 2010 | 01:22 PM
SleevelessSteve's Avatar
Alright guys, so I'm going to give a machine shop a try i think. At least having them evaluate the head can't hurt a thing.
Old Jan 11, 2010 | 03:43 PM
  #25
dont pay until its fixxed.. bottomline... test drive and get a compression test tooo.
Old Jan 11, 2010 | 03:56 PM
  #26
Noted, thank you.
Old Jan 16, 2010 | 02:28 PM
  #27
so what is your status with your ride?
Old Jan 16, 2010 | 07:45 PM
  #28
Well I'm fixing it myself, ended up ordering a cylinder head so that should be here tuesday or wednesday. Got the ignition coil today, and I'm still waiting on the new plug and the gaskets for everything. Should be back on the road by next weekend I hope.
-Steve
Old Jan 17, 2010 | 08:51 AM
  #29
are you going to change out both head gaskets.. dont skimm this process...
Old Jan 17, 2010 | 07:44 PM
  #30
Well i ordered all of the gaskets so i have two sets i believe. haven't gotten them in the mail yet. I guess i should just change both out while i have all the laid out anyways, eh? Is it bad to only change the one gasket out or something?
Old Jan 18, 2010 | 03:27 AM
  #31
mt_goat's Avatar
Is this a new head or used?
Old Jan 18, 2010 | 05:31 AM
  #32
well its kinda like this.. would paint your house from the bottom up to the top... or would you do it the right way and paint from the top down...
Old Jan 18, 2010 | 09:05 AM
  #33
LifeOnABoard's Avatar
Originally Posted by SleevelessSteve
Not fun. It was cold as too, and i was wearing a damn suit.
Was the suit sleeveless?
I don't like the thought of tapping a hole above a cylinder. There's only one place for the loose burrs to fall....
Old Jan 18, 2010 | 09:32 AM
  #34
put grease on the die.. the shavings get trapped in the grease..
Old Jan 18, 2010 | 09:36 AM
  #35
ibeamtaco's Avatar
i am not sure about ware you are but in cali my family has a shop by the bureau of automotive repair standards we have to warranty all work for 1 year unless otherwise stated on invoice or if failure was caused by you so pretty much all part failure and workmanship failure is on shop that did plugs last i would talk 2 them
Old Jan 18, 2010 | 11:03 AM
  #36
If you're lucky you'll get 90% of them to stick.
Old Jan 18, 2010 | 11:56 AM
  #37
thats why you get a vacum from harbor frieght tools and putt the vacum line down in the spark plug hole and suck out the cylinder and make sure you got everything else... just how the do it at the dentist office when the suck the crud out of your mouth...
a electric vacum will work the best make sure you have a catch can setup.. so you dont suck the trash in to the pump..
Old Jan 18, 2010 | 07:08 PM
  #38
redwilly's Avatar
The Snap On kit I used to fix this has a tool to evacuate the debris.
I also looked in the cylinder with a bore scope to verify no shavings remained.
I really think you should look into the threaded insert fix, Mines been working for 9 months, and I've put 3 more in since then in other cars.
Ford 5.4 are aluminium heads and they use it as an OEM fix for this problem.
Frank
Old Jan 19, 2010 | 06:05 AM
  #39
I know that a lot of times it just makes sense. Primarily I'm just paranoid that one evil little burr would fall between the wall and the piston. It would just sit there on a ring and score the wall until it finally disintegrates. But I dunno, maybe it wouldn't hurt the wall at all. I've never had to do it and don't ever want to make that decision!
Old Jan 19, 2010 | 01:29 PM
  #40
pay the money and get the snap-on tool...
or do what i said before i bet its alot cheaper than buy the snap on tool..
plus you will not have any problem taking it back to harbor frieght tool they have better return policy than sears.
