Bilstein 5100 Question
Old Oct 10, 2015 | 07:51 AM
83's Avatar
83
I know, there are pages and pages of discussion about these...which is part of the problem. Tons of discussion but without sitting down for a few hours of reading, I haven't seen my question addressed with just skimming.
I'm still happy with my decision to buy these, but for some reason I thought both the fronts and backs were adjustable. But only the fronts are.
Trucks and 4Runners alike have an issue with rear end sag. So what's the thinking behind a built-in method to raise the front, but not rear suspension? I figured I'd keep the front at stock height and just bring up the rear a tiny bit. Instead I'll just be keeping everything stock.
Either way these will be a good upgrade to the truck, but I'm a little dissapointed that the rears aren't adjustable...
Old Oct 11, 2015 | 09:22 PM
SharpStick's Avatar
It's a design thing.
The perch incorporated on a coil over is what enables that adjustability -adjustable perch = adjustable height. No perch, no adjustability.
The 5100s are great. I run Tundra 5100s on my 4R. With the saggy ass in back, I use OME 891s with OE Dodge 2500 front shocks. Of course - go figure - those OME 891s are slowly sagging. Guess it's a Toyota thing. Gives 'em charm.
STICK
Old Oct 12, 2015 | 05:41 AM
skypilot's Avatar
They ride stiff. I smoke rear shocks every couple of years, the heat just kills them.
Old Oct 12, 2015 | 08:39 AM
83's Avatar
83
Gotcha. I just didn't realize there were so many people interested in raising the front. I like the rear a little higher. But I guess there are compatible with small lifts, so that's part of their popularity.
I just had a shop swap the front coils from the old ones to new ones, so we'll see how it rides one I get the fronts back on & can drive it.
Old May 10, 2016 | 11:06 PM
SharpStick's Avatar
If you like the back to ride high and don't haul much, the FJ80 front spring swap raises the rear of the 4Runner more than the 890/891 option.
STICK
Old May 22, 2016 | 11:59 PM
wheels&more's Avatar
You can also use OME lift spring for the FJ80. Using springs is a cheap and effective to lift the rear although will sag under load.
Old May 23, 2016 | 07:36 AM
KZN185W's Avatar
with the front at stock height, the rake would be too much if he will use the LC80 springs. I would recommend that the OP install new the 1999-2000 SR5 Highlander Edition rear springs as those will provide a 1-inch lift over the stock height.
STICK
jashoeuh
Nov 18, 2024 08:08 AM
DeathCougar
Apr 1, 2018 11:29 PM
Shagool22
Aug 14, 2015 12:24 AM
Gevo
Jul 29, 2015 11:15 AM
gmonnie123
Jul 26, 2015 02:44 PM
