Biggest tires for PP lift
Old Jan 1, 2007 | 10:19 AM
outrages112's Avatar
i have searched, cant find anything believe me. what is the biggest tire i can go with when i do my pp lift with springs and bilstein shocks.i hope 285-75-16 but cant find any fore sures? its all just looks will probably never see a trail.
thanks
Old Jan 1, 2007 | 10:29 AM
Elton's Avatar
need atleast 2-1/2'' to clear 285s
Old Jan 1, 2007 | 10:30 AM
d0ubledown's Avatar
go for a 32" then. 265/75/16 or if you can fit 15's..there are much more possibilites. no sense in trying to put 33s if its not going to see any trails. 33's may fit, but it may require more trimming and depending on what wheels you use..may rub uca's or frame.
Old Jan 1, 2007 | 10:48 AM
Bob_98SR5's Avatar
i have the pp springs and bilstein shocks. 33s will look stuffed and you will rub. if you want a good look, buy MTs in 32s. if you want good looks w/ still an aggresive look but better road manners, get a nice set of ATs (revos, terra grapplers, etc)
bob
Old Jan 1, 2007 | 10:51 AM
ok so with my 16" wheels 275-70-16 or 270-75-16. i always just assumed wider would be better for handling but it probably will be unnoticable
Old Jan 1, 2007 | 11:32 AM
Bob_98SR5's Avatar
265/75/16
Old Jan 1, 2007 | 11:49 AM
Beerdrinker's Avatar
this was my result, YMMV
https://www.yotatech.com/forums/f2/pics-these-rims-2-bling-bling-285s-91320/
I haven't done any serious off camber stuff with the tires yet, but have been running around in the mojave desert, mostly on motocycle trails and dirt roads and still don't rub.
Old Jan 2, 2007 | 08:11 AM
Bennito's Avatar
Believe RavenCR also ran 285/75r16 tires on PP springs. he did a fair amount of whacking and trimming.
Old Jan 3, 2007 | 12:15 PM
BADLNDS's Avatar
32"...265-75-16
-b
Old Jan 6, 2007 | 10:08 AM
PO2SIMS's Avatar
I have PP springs and have no rubbing on my 33x10.50x15 BFG AT. 285/75/16 are a little wider so may rub, but you can try 255/85/16, they are like a 33.5x10. Otherwise just stick to the 265.
Old Jan 14, 2007 | 07:09 AM
so i know this is hardly anybody's style around here but i just picked up a set of 20" wheels antera type 301. i am going to still raise the truck and the tires are 275-55-20 31.9" so no small sidewall it has descent meat on it. i think its gonna look good, guess i'll just have to find out.
Flying91
45
Apr 11, 2024 04:39 PM
okamikai
Apr 30, 2018 10:19 PM
Sep 4, 2015 09:27 AM
nickbeauregard
12
Aug 7, 2015 06:04 AM
coffey50
Jul 28, 2015 10:55 AM
