Biggest Stock Tires
Old Jan 6, 2003 | 11:28 AM
dlotoy4runner's Avatar
Question Biggest Stock Tires
What are the biggest tires I can put on the stock 16inches? I was thinking about 265/75/16 or can I go wider? or taller?
Old Jan 6, 2003 | 11:37 AM
RTdawgs's Avatar
265/75/16 or 275/70/16
Old Jan 6, 2003 | 11:40 AM
data's Avatar
Senior Member
I ran 265/75/16's for a while with no problems.
Old Jan 6, 2003 | 11:43 AM
I have 275/70/16 Bridgestone Dueler H/Ls
Old Jan 6, 2003 | 11:55 AM
Darren's Avatar
Guys, he's talking wheels, not lift.
Many people are running 285/75's. I was just looking at the specs for the MT/R's in that size and they recommend a minimum 7.5" rim. Hmmm. Stock is 16x7. Not sure if that's the biggest or not though that you could safely fit.
Old Jan 6, 2003 | 12:31 PM
RTdawgs's Avatar
Old Jan 6, 2003 | 02:27 PM
kc4runner's Avatar
I have BFG AT KO's 275/70/16 on my stock rims (no lift)....
Old Jan 6, 2003 | 03:09 PM
INsr5runner's Avatar
I have 265/75/16, on AR rims which are 16/8, but still 16's...anyways my point is that My tires rubbed my stock running boards, and I was forced to take them off temporarily...
lots of people here are running these same tires, without rubbing, but mine did for some reason
Old Jan 6, 2003 | 03:37 PM
RTdawgs's Avatar
cuz your 8" wheels are wider and because they make your tires stick out farther.
Old Jan 7, 2003 | 04:19 AM
All these post are making me confused.
I guess if I put Goodyear MT/R's 265/75/16 on my 16" rimes on my stock '02, would it fit? I rather have a taller tire than wider. Cheap man's lift :rolleyes:
Thanks,
Danny
Old Jan 7, 2003 | 12:41 PM
Matt's Avatar
What's the largest tire size for 15 inch stock wheels? I've just gotta do something about the look of my 4 X 4...
Old Jan 7, 2003 | 12:58 PM
kxpaul's Avatar
15" rims
What year, and modle?
31x10.50x15 are a real common tire replacemnt size.
Old Jan 7, 2003 | 01:15 PM
Good Times's Avatar
danny (dlotoy4runner)
you should have no problems fitting the 265/75/16's on your 4runner. it will ride abit taller but not too much that u'll notice.
most of the guys here run the 265/75/16's or the 285's so you should have no problems.
Matt's Avatar
I've got a 2002 SR5.
Old Jan 7, 2003 | 01:19 PM
Good Times's Avatar
matt:
265/75/16's should be fine...
or u can join kc4runner ang get his setup too...
"I have BFG AT KO's 275/70/16 on my stock rims (no lift).... "
either way u'll be fine. if you want to jump to 285's u'll have to lift it abit (a few inches)
Old Jan 7, 2003 | 01:30 PM
Darren's Avatar
Thanks,
Danny
Your original post was talking about fitting certain sizes of tires on rims, not how big a tire can you put on without a lift. The others were expecting to see the latter which is why my response. That's okay, we'll help you out!
Yes, 265/75 MT/R's fit. That is what I ran prior to lifting mine (and still run until they wear out). Many people run this size tire stock which is the tallest you can fit without rubbing. The MT/R's in that size measure 31.0". Other brands will vary. I gained anywhere from .5" to 3/4" "lift" depending on where the measurements were taken as expected.
I'll have my pics available once again for the masses to see later tonight that shows what this looks like.
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
djpg2000
Nov 11, 2020 04:56 AM
coffey50
Jul 28, 2015 10:55 AM
DrZero
Jul 13, 2015 09:59 AM
