Biggest lift for 96 4runner?
Revtek makes a 3" kit. thats the biggest kit, and the biggest amount of lift you can get. you can piece components together to make your own "lift kit" too. 4Runner Suspension Options
so 3" suspension, and 3" body I assume. Definately throw some better gears back there
33's are just a tad bit too small for my taste..I had a 94 Z71 with SFA setup and a 17" suspension lift, and 44" tires for just over a year. 33" tires compared to 44" tires is like comparing a midget to a giant
I will 'settle' for 35" tires, but if I can will squeeze bigger.
Originally posted by EOF
So whats the biggest tire you can clear with the 3" lift..33's? I wan't to clear atleast 35's.
i know someone who has a 4runner (dont know the year) but i think he has a 6.5" lift and is running 35" thornbirds... btw, that chevy sounds sweet. couldnt have been street legal though... not in my state anyways. i met this guy who has a old GMC pickup with some like 6 foot tires... he took two rear ends off of soem tractors (i think) and rigged them up as his wheels for his truck.....:eek: :eek: :eek: :eek: its a crazy ride... he does mud races with it. has two big snorkels coming up out of the hood.
Retro fit a Tacoma lift, like the 6" Trail Master lift. The front is easy, since the rear of the tacomas are leafs youd have to do some mix matching. Run a OME HD coils in the rear with a 2.5-3" Spacer, but you will have to extend your links to do that. This is just a thought on what to do to clear 35s.
If you are serious about this you have to decide what you want out of it. Do you want a pre runner, a rock crawler, or street cruiser? If you wamt a pre runner check out http://www.camburg.com or http://www.atsracing.com they both make 6" long travel kits for the front end and they will also custom fab you a rear setup. If you want a crawler get some FJ-80 landcruiser straight axles and swap them over with lots of custom fabrication. if you want a street cruiser either get a revtek or cornbred style spacer lift and then a 3" body lift. Any of these shold clear 35's. Good luck!
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
FS[NorAtl]: 05+ tacoma leveling lift front MA
akaphilly
Jul 9, 2015 02:18 PM
skoti89
Jul 6, 2015 07:45 PM
