Biggest lift for 96 4runner?
Old Aug 28, 2002 | 09:32 AM
EOF's Avatar
EOF
Whats the biggest lift out there? And who sells it?
Travis
Old Aug 28, 2002 | 09:43 AM
RTdawgs's Avatar
Revtek makes a 3" kit. thats the biggest kit, and the biggest amount of lift you can get. you can piece components together to make your own "lift kit" too. 4Runner Suspension Options
Old Aug 28, 2002 | 09:45 AM
EOF's Avatar
EOF
So whats the biggest tire you can clear with the 3" lift..33's? I wan't to clear atleast 35's.
Old Aug 28, 2002 | 09:52 AM
dbui27's Avatar
You'll need a BL to fit 35's. You'll also either want to change gears or get a SC to get some more pep back in the accelaration.
dave
Old Aug 28, 2002 | 09:56 AM
EOF's Avatar
EOF
so 3" suspension, and 3" body I assume. Definately throw some better gears back there 33's are just a tad bit too small for my taste..I had a 94 Z71 with SFA setup and a 17" suspension lift, and 44" tires for just over a year. 33" tires compared to 44" tires is like comparing a midget to a giant I will 'settle' for 35" tires, but if I can will squeeze bigger.
Old Aug 28, 2002 | 09:57 AM
RTdawgs's Avatar
i can clear 33s (285/75s) with 2.5", but 3" will do good too. If you want 35s, itll take 3" body and suspension, plus lots of trimming. i know a guy with 33x1250s who rubs with 2.5" suspension and 3" body. so 35s are a stretch.
Old Aug 28, 2002 | 09:59 AM
EOF's Avatar
EOF
I don't mind doing a little trimming to fit the bigger tires. I certainly won't be flexing enough to make a difference..I am not a trail guy although I do enjoy playing in the mudd
Old Aug 30, 2002 | 11:50 AM
rowan's Avatar
i know someone who has a 4runner (dont know the year) but i think he has a 6.5" lift and is running 35" thornbirds... btw, that chevy sounds sweet. couldnt have been street legal though... not in my state anyways. i met this guy who has a old GMC pickup with some like 6 foot tires... he took two rear ends off of soem tractors (i think) and rigged them up as his wheels for his truck.....:eek: :eek: :eek: :eek: its a crazy ride... he does mud races with it. has two big snorkels coming up out of the hood.
Old Aug 30, 2002 | 04:30 PM
EClayton08's Avatar
Guest
Retro fit a Tacoma lift, like the 6" Trail Master lift. The front is easy, since the rear of the tacomas are leafs youd have to do some mix matching. Run a OME HD coils in the rear with a 2.5-3" Spacer, but you will have to extend your links to do that. This is just a thought on what to do to clear 35s.
Old Aug 30, 2002 | 05:59 PM
RTdawgs's Avatar
From what ive heard, the front crossmember is a different width than the width of the Tacomas. so b/c of that, the tacoma kits wont work. but if im wrong, i would convert the rear to leafs before trying to lift the rear 6" w/ coils. There are so many adjustments you would have to make.
Old Aug 30, 2002 | 10:37 PM
4cedRunner's Avatar
If you are serious about this you have to decide what you want out of it. Do you want a pre runner, a rock crawler, or street cruiser? If you wamt a pre runner check out http://www.camburg.com or http://www.atsracing.com they both make 6" long travel kits for the front end and they will also custom fab you a rear setup. If you want a crawler get some FJ-80 landcruiser straight axles and swap them over with lots of custom fabrication. if you want a street cruiser either get a revtek or cornbred style spacer lift and then a 3" body lift. Any of these shold clear 35's. Good luck!
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
akaphilly
Jul 9, 2015 02:18 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
skoti89
Jul 6, 2015 07:45 PM
