Best year?
Old Oct 12, 2012 | 02:10 PM
Yota Runner's Avatar
I was thinking the same thing...
Old Oct 12, 2012 | 05:33 PM
mynameistommy510's Avatar
Paddlenbike hit it just right. If the best 3.4 is your deciding factor, you should be wayyyyy more worried about buying a used engine regardless the year of make.
The 3.4 in my 96 is easily the equivalent of a V8 in a pickup, weight to power ratio. Still running flawless after 230K.
Old Oct 12, 2012 | 09:29 PM
BMcEL's Avatar
Uhh...
Old Oct 12, 2012 | 11:54 PM
KZN185W's Avatar
The 1999 - 2002 also have slightly improved interior features and also a few features that were not on the earlier models. Also, the 3rd body mount located near the bottom point of the B-pillar was not present in the earlier models.
Old Oct 13, 2012 | 01:01 PM
  #25
Dirt Driver's Avatar
Originally Posted by 88runnasr5
not doubting you in anyway just wondering if you actually inspected the heads? and internals may look the same but they are totally different from forged and cast.
Eh, forged and cast parts don't look the same...
okay well i guess everyone on yotatech is on some good drugs or something, this is why i stay off this forum but for some reason i assumed since there is a whole 3.4 swap forum that someone would know any differences in designs, guess not.
Just because you assume there were differences and assume you are right doesn't mean you are. 5VZ-FE power and torque never changed, which is a good indication that nothing affecting output changed. The first-year engines had a head gasket issue already mentioned. That, unlike the 3VZ-E's problem, didn't require redesigning the engine.
if toyota stood behind there 3.4 and didnt make a single change why is there 2 or 3 different models of the rz series and i believe the same for the re series as well. heck if memory serves me they even fixed the early 3.0 problems in 94 with better head studs and gasket.
What do the early 22R-E, later 22R-E, 2RZ-FE, and 3RZ-FE have to do with a 5VZ-FE? One word: nothing.
Old Oct 13, 2012 | 09:07 PM
  #26
BMcEL's Avatar
Redesigned the engine, huh? Interesting.
Old Oct 14, 2012 | 08:10 PM
  #27
kornhuskerwizard's Avatar
i think this forum is great. for you to say people are ignorant is your own opinion. theres some very intelligent users on here and also very creative. as for your question i havent had any problems with my 97 limited. if i was in your position id find a used complete engine, check compression, replace timing belt, water pump and put it in. but im always on a low budget, but i also beleive in qaulity parts too.
good luck!!
Old Oct 15, 2012 | 11:51 AM
  #28
Man4God's Avatar
Also, don't be put off by leaky valve cover gaskets. Just tighten them back down every 60K or so.
My 3.4, besides being a dog (to me), has been perfect. Never had so much as a check engine light on it in 196K.
icentropy
Sep 16, 2020 02:47 PM
jasonty
41
Dec 23, 2018 01:00 PM
Road Bull
Oct 10, 2015 04:55 PM
irritech
Jul 27, 2015 05:15 PM
daddio
Jul 18, 2015 10:20 AM
