best subs?
Old Mar 9, 2003 | 01:54 PM
  #41
impulsebrklyn's Avatar
you guys fogot alot of good subs on you lists
Digital Design very very very loud all of there subs are good more spl then sq though
Adire Audio --- Brahma (have a 10" comign be here tommrow)
bad ass sub good sq and spl mix
Resonant Engineering --- XXX bad ass sub good sq and spl mix
Image Dynamics --- IDMAX great sq sub -- Ran two myself took up to much room though -- sob dont make 10" in idmax or i would have replaced my 12"s with 10"s-- IDQ great budget sub
JL Audio makes great subs but i think there a ripe off
Kicker L7's are a nice bang for your buck also
Dont buy crap cause it will sound like crap. Installation makes everything, its the most important aspect. Chris
Old Mar 9, 2003 | 03:07 PM
  #42
Los Gatos?'s Avatar
I have to pimp out Crystal...
Get a CMPx2!! You can pick them up for around the same price as a Brahma, etc, and you can be an original!
Old Mar 9, 2003 | 03:23 PM
  #43
Bumpin' Yota's Avatar
If you dont want mainstream and you want a sub that will win both sq and spl competitions get the Beyond Audio Inhuman.... very very bad ass sub.
the Beyond Audio Lineup
http://www3.sk.sympatico.ca/hebig1/index2.html
the Beyond Audio Forum to ask quesitons
http://pub26.ezboard.com/bcaraudioforum87927
ps - not saying that the others wont do this, but the inhuman is such a sleeper sub and the antithesis of mainstream.
Old Mar 9, 2003 | 04:32 PM
  #44
doink's Avatar
thanks for all the info guys. i have another question along these lines. how do you bridge an amp? my buddy was saying if i bridge my current amp, i could run an audiobahn woofer that he has in his car.
Old Mar 9, 2003 | 04:50 PM
  #45
A normal class a/b amp that has 2 channels usually can be bridged into a single channel. Usually this entails using the right - and left +
(I'm not exactly sure if it's that or left - and right +, as it's been a long time since ive bridged an a/b amp, so check your amp's instruction manual on bridging)
True mono block amps have only one channel to begin with...
Old Mar 9, 2003 | 05:01 PM
  #46
doink's Avatar
so, could i bridge my sony 760 watt amp to run a single audiobahn ALUM12Q sub or solobaricl5 sub?
Old Mar 9, 2003 | 05:06 PM
  #47
i think so, but what is it's model number? in the mean time im going to look at sony's site.
Old Mar 9, 2003 | 05:08 PM
  #48
doink's Avatar
i honestly dont know about the model number. you mean on the amp right?. to be honest, id ont think they even make it anymore. i bought the whole system from my buddy about a year ago, so, who knows..hehe. thanks for dealing with the dumb questions everyone
Old Mar 9, 2003 | 06:10 PM
  #49
Del's Avatar
Del
If you have the instructions, they should tell you how much power you'll get if you bridge they channels. If that's the amp I'm thinking of, you will more than likely have enough power. I've gotten everything though my uncle at Sony and am happy with everything. I'm runnung two 12's (competition) and you can hear me coming far away. Once I get my mono amps, whoa watch out!
Old Mar 9, 2003 | 06:12 PM
  #50
Del's Avatar
Del
Oh yea, Bumpin' Yota, I eventually want to make a custom enclosure with amp racks and everything. Are there any kind of materials you recomend?
Old Mar 9, 2003 | 06:28 PM
  #51
jtrent's Avatar
I just bought a Kicker L5 10 in the big vented box (2.25 sq ft I think). I am powering it with my Audiobahn A18001DQ amp, which I know is total overkill for this sub, but oh well...what can you do? Anyway, I've been very happy with it for the most part. It's not as clean as the sealed enclosures I've been used to in the past, but it sounds nice and hits harder than any single 10 I've ever heard. At $349 list, it's good bang for the buck if you've got a good amp to push it.
Old Mar 9, 2003 | 06:44 PM
  #52
trangk's Avatar
Originally posted by Cebby
More modest??? I think not. Your rig is a who's who of top SQ gear. I'll bet it sounds incredible!!. Do you have a stealth install or is everything showcased? Do you run the separates in the stock locations, or in the kickpanels? My system wants to be yours when it grows up...
My home theater is more tame than your. All Yamaha electronics, Boston powered 10 sub, and MB Quart .5's all around.
I'll have to look around, I might still have some replacement domes for the Vifa's. I'll send them to you if I do since I don't have any Vifa's anymore.
It's mainly stealth, the amps are showcased but not a showcar setup (see picture ... that's the amp rack/sub box that I just built but haven't covered in vinyl yet). Right now I'm running the speakers in the stock location with the tweeters flush mounted in the stock kickpanel area. Haven't had time to make kickpanels (and also would like to go to a 3way setup). Even in the stock location I score pretty high in imaging, but do lose points on stage height and depth. With kickpanels, it would sound so much better ... one of these days I'll eventually get there
Your system is going to be awesome with those Dynaudios. Put them in kickpanels and get a good matching sub and you'll blow everyone away
Old Mar 10, 2003 | 03:46 AM
  #53
MDF (Medium Density Fiberboard) is the best. Some hardware stores mislabel it HDF (High Density Fiberboard.) But the stuff ya need to use weighs about 100lbs for a 4' x 8 ' x 3/4" sheet. Any typical saw can be used to cut it - table or circular saw. To join the sides, you'll need Elmer's Probond and #8 2 1/2" drywall screws. Be sure to countersink a pilot hole or the wood will split when the screw begins to dive. Also do not screw into the edge of the MDF if the end is any closer than 3" Once the box is built, I tend to install bracing if needed then attack the interior with fiberglass. This ensures that boxes are truely sealed except for the port.
enjoy!
Steve
Old Mar 10, 2003 | 05:35 AM
  #54
doink's Avatar
when getting a new sub, do you have to match the ohms the sub has to the ohms the amp has? or does it not matteR?
Old Mar 10, 2003 | 01:42 PM
  #55
Basically, the amp will have a minimum impeadance that it can operate at, and that is the impeadance (ohms) you want to shoot for.
I break that rule every now and then and doing so can be very dangerous to the equipment if you dont know your system EXTREMELY well.
If the amp says dont go below 2ohms, you dont want to go below that.
Steve
Old Mar 10, 2003 | 02:20 PM
  #56
x4RunnerTM7x's Avatar
im an eclipse fan because of the well rounded performance...when it comes to subs, its up to you...do you want booty bass, tight bass, rumble (i dont think anyone likes that though),...you should really get a custom box...it makes a world of difference...sub positions is key too for what you want in the bass department
Old Mar 10, 2003 | 02:33 PM
  #57
I had a set of 88150.4's loved em. They took 4kw quite well too....lol
Steve
Bourbonblues
Dec 15, 2017 05:43 PM
mreagen
Sep 8, 2015 03:46 PM
lectric80
Aug 11, 2015 12:02 AM
Esibnitsud
Jul 30, 2015 08:19 PM
