Ball Joints...When to replace?
Old Jan 22, 2004 | 12:59 PM
Denk's Avatar
Does anyone know what the symptoms are for bad ball joints on a 1990 runner? How do you know when they need to be replaced? Guy at the shop says i need new lower ball joints before the alignment? Cuz if those joints are bad, then they will still mess up the alignment, right?
Old Jan 22, 2004 | 07:07 PM
lunatic14r's Avatar
jack the front up and grab the wheel at 12:00 and 6:00 and try to move it in and out if it moves they are bad also look at them and see if the boot are torn thats a good sign that they are on there way out. You cant align a car with bad ball joints you will never get it in to spec.
Old Jan 23, 2004 | 04:47 AM
MTL_4runner's Avatar
Make sure you are looking at the ball joint because if the wheel bearings are going then the tire will wobble a bit from that too. Should be pretty obvious if they need replacing.
Old Jan 23, 2004 | 09:34 AM
Denk's Avatar
Does the boot around the joint have to be busted or leaking for the joint itself to be bad? And what is the probability that 3 of the ball joints needing to be replaced and not the fourth? Thanks.
Old Jan 23, 2004 | 11:02 AM
The boot does not need to be damaged at all. You are looking for lateral movement (ie side to side) of the ball joint. If theer is any, replace it/them. Who knows what the probability is, get under there and check them yourself.
Old Jan 23, 2004 | 11:21 AM
44Runner's Avatar
Not at all.
It doesn't take much to toast a ball joint, and the bottom ones always seem to go first. I would go ahead and replace both. The jack up and shake is the standard method of ball joint testing
Old Jan 23, 2004 | 12:11 PM
Denk's Avatar
thanks yotatecherz...you just confirmed my suspiscions.
Old Mar 2, 2004 | 10:20 AM
Bumpin' Yota's Avatar
Well I love this search button...
But when I jack up the front, you mean jack it up in a manner such that neither the LCA or UCA are bearing any weight? In other words full drop of both tires?
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
msane99
Jul 27, 2015 06:14 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
1994toyota
Jul 17, 2015 03:03 AM
