Aux block oil pressure fitting size
Old Sep 28, 2013 | 07:45 PM
vasinvictor's Avatar
I'm needing the oil pressure fitting size that's beside the sending unit on the block. Can't find it- anyone know off-hand?
Old Sep 30, 2013 | 12:47 PM
bump- I'm ready to start hooking up my turbo oil lines, and want to have a fitting ready to put in the hole...
Old Oct 2, 2013 | 05:01 AM
Found my answer here. And thus documented here for future searchers:
"If it is like the 5VZ engine, that plug should be a British Standard Pipe Thread, but a 3/8" NPT will fit into it and work fine. That is what I use all the time. There is a very slight difference between BSPT and NPT, but it takes like about 10 turns before it is a real issue and you should not be anywhere near there.
Here is a little trick if it is kind of tight, put the fitting on an ice cube for a couple of minutes and it should go in much easier.
If you want a real BSPT check at one of the larger NAPA stores, they sometimes have that stuff in stock.
Gadget"
Source: http://www.customtacos.com/forum/showthread.php?t=26783
This would be useful for anyone wanting to hook up another pressure gauge, oil temp, turbo oil feed- anything that needs oil pressure.
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Sep 4, 2015 09:27 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
Gamble_STi
Jul 7, 2015 07:54 PM
