Aux Back up/work lamps ..rack mounted ??
Old Sep 17, 2006 | 05:37 PM
fireteacher's Avatar
where did you guys tap your reverse lights at? the light them selves or under the dash?
Old Sep 17, 2006 | 05:49 PM
wjwerdna's Avatar
i did it near the lights themselves, not the best, but the easiest...
Old Sep 18, 2006 | 04:07 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
i followed the wire up to inside the cab to the harness under the drivers seat. to be sure i used a voltage meter to check since the wire changed colors at the harness. it made much more sense to tap into it there than back at the light. i would have had to run back to the lights to where i spliced in, then run back to the cab for the switch and relay, then BACK to the rear to finish the circuit. lots of wasted wire if you go that route.
Old Sep 18, 2006 | 04:12 PM
Originally Posted by fireteacher
in his write up, he said that when in the off possition even his reverse lights dont operate! i would prefer to just make it to where there on all the time when in reverse as your only in reverse a few sec. plus, the kit came with a switch.
the lights only dont come on when in the off position (as i said above), but the switch is NEVER in the off position. in the up position, where it is 99% of the time, all 4 lights come on when I am in reverse, just as you want it. In the down position, just the aux lights come on (useful for camping or lighting up path for rigs behind you at night). I wanted the option to be able to turn off my aux. lights so im not blinding someone if i am in a situation to reverse right in front of someone. it just so happens that when i turn those off, the way i have it wired, my stock ones dont come on either. a perfectly acceptable situation since if i am in that situation, the car behind me is going to be able to see me anyway
mskalmus
May 28, 2017 07:51 AM
jon.r
Jul 11, 2015 03:34 PM
skoti89
Jul 8, 2015 12:05 AM
Suprarossa
Jul 6, 2015 05:21 AM
elwood73
Jul 5, 2015 07:07 AM
