Automatic Gear Shifter won't come out of park without rocking the car
Old Aug 24, 2011 | 07:12 PM
t-t-t-taylor's Avatar
Basically have to force it into drive. Rocking the car from behind with help. Currently have it parked in Neutral with parking break on.
Any Ideas?
99 4Runner 4-wheel drive
Old Aug 27, 2011 | 02:41 PM
mynameistommy510's Avatar
This most likely has to do with the gear shift solenoid. When you press on the brake pedal, you should hear a click near the shifter. If not, The plastic cover around the shifter should come off. a large brown cable runs to the shifter. Check its connection. If all fails, i've heard of a shift override on the right portion of the shifter that can be depressed to shift no matter what.
Old Aug 27, 2011 | 03:59 PM
KZN185W's Avatar
maybe the brake switch is dead? step on the brake pedal and ask someone to check if the brake lights light up.
Old Aug 29, 2011 | 07:34 AM
CTRJ's Avatar
Neutral safety switch.
Charecter1
Nov 6, 2023 10:08 AM
mskalmus
May 28, 2017 07:51 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
Jnkml
Jul 6, 2015 01:20 PM
