Auto tranny stopped downshifting
Old Aug 30, 2010 | 04:03 PM
R.DesJardin's Avatar
A340's
Originally Posted by coonhound130
what is VSS and TCM ? TPS is throttle position sensor correct ? Thanks .
Had 3 shops tell me a minimum of 3 grand for a rebuild and that was best case senerio and nothing major was wrong with it .
the rear diff has a metal on metal sound when you turn the yoke , noticed it when doing u-joints last week , pinion seemed kinda loose to me .
VSS -vehicle speed sensor, they are are trans and t-case.
TCM- trans. control module, basically the computer that shifts the transmission. Not sure if it's a seperate unit on that new of a Toy but the old ones were different than the ECM(engine control module).
I'm saying it's sounds electrical related. If was mechanical it would probably be slipping and not even wanting to shift manually. IMHO
Old Aug 30, 2010 | 04:16 PM
coonhound130's Avatar
how could i test for the problems without any codes being thrown ?
Old Aug 30, 2010 | 05:33 PM
Testing
The TPS, VSS can be tested with a volt/ohm meter. The specs are in service manual. The TCM would be making sure the connections are good, not coroded etc.
Old Aug 30, 2010 | 05:46 PM
where is the tcm ? i have searched with no luck . where could i find a service manual download?
Old Aug 30, 2010 | 06:22 PM
  #25
I have searched google and other places for 2 hours with no mention of a TCM for a 99 4runner . Where is it located ?
Old Aug 30, 2010 | 10:35 PM
  #26
brian2sun's Avatar
I don't think the A340F tranny has a TCM, I think it's just controlled with the ECM, but I'm no tranny expert.
FSMs:
http://www.ncttora.com/fsm/index.html
Old Aug 31, 2010 | 03:04 AM
  #27
Pretty sure it is not electrical seeing how i have no cel coming on . I think it is just a hunk of junk all together . Nothing but bad luck and have to replace or fix something on it EVERY week ..
Old Aug 31, 2010 | 05:12 AM
  #28
ScottyC's Avatar
Its electrical. Trust me.
Also, a CEL doesn't have to come on. It can be simply stored. Have you pulled codes with a scanner? I will put money on the solenoids or a TPS being out of adjustment. With the mileage you have on the car, I would do the solenoids as well. There is a link in the below write-up that I did that has a cheap source for solenoids for the tranny. IIRC they are around $130 for all three solenoids.
Read through this:
http://www.toyotaholics.com/support/...sp?TOPIC_ID=19
Old Aug 31, 2010 | 02:08 PM
  #29
Scotty-- will read that . Haven't pulled any codes because the light hasn't been on in a few months since the spark plugs went south on me . I will try and see what I get . Thanks alot for the info , I sure hope it is electical ....
Old Aug 31, 2010 | 02:25 PM
  #30
WOuld me driving it for a month or so like that having to manual downshift hurt the tranny ?
ALso how many qts of fluid and what type for the 99 4runner???
Charecter1
Nov 6, 2023 10:08 AM
Liadrin
Apr 25, 2022 02:54 PM
Liadrin
Sep 1, 2015 06:44 AM
Iceman4193
Jul 15, 2015 04:48 PM
Jnkml
Jul 6, 2015 01:20 PM
